375 Key Hub
I was trying to download the 375 key hub of AndyMark, however every time I try to download the step file, it just opens the product in another tab. Does anyone have a fix for this or happen to have the file they could send me??
Are you trying to right click and Save As? Then drag and drop into your program.
I’ve tried that, and it doesn’t work.
Email AM, seems the file just isn’t there.
I have thanks, just wanted to see if anyone happened to have the file laying around so I didn’t have to wait until tomorrow.
Aloha!
From the looks of it, you are trying to down load the step file for the (AM-134a) 375 Key Hub… I agree the links are both broken…
Have you tried the (AM-0134) Key Hub?
http://www.andymark.com/product-p/am-0134.htm
The CAD file works fine and the general specs listed are the same. Though it does not show the height…
Could work in a pinch… just extrude a bit if needed… :slight_smile:
Good Luck!
Thanks so much! I had not tried that.
Given it is a fairly simple part I tried to download the PDF file and model the part. Unfortunately there is an issue with that file as well.
I did find a PDF this one, but it does not appear to be the 134a version.
http://www.robotshop.com/andymark-375-key-hub.html
