We are planning on using a 2 stage gearbox (the VexPro 3CIM Ball Shifter) for the first time next year. We used the JVN calculator to do some calculations on what gear ratios to use, and we came up with this:
https://i.imgur.com/8bpXmaS.png.
We tried to match the real-life speed in high gear to be a little faster than our robot last year, and the low gear to be what seemed to be a reasonable amount slower. We wanted to require minimal changes if we have to use pneumatic wheels, so with this configuration, only the third stage has to change to maintain a reasonable speed if we use 6in wheels. The only real issue we see here is that the pushing current draw in high gear seems too high, but programming team thinks they can programmatically downshift when pushing in high gear to make that a non-issue. Is there anything else wrong with this gearing for our plan? We’d like to order parts ASAP so that we can spend some time in the offseason practicing putting together the gearbox and a drivetrain.
