I modeled the hook from the end of the lift peg so teams can 3D print it and get their own.
A bit of an extra note since I lost the ability to edit.
After printing it, it appears that it has a very tight fit in the spring. In fact, it’s so tight that you need to install it by actually screwing it in to the spring, letting the metal dig through the plastic. Because of this, you will want to use a good amount of infill to keep it from shearing. I printed it at 20% and I nearly snapped it trying to get it in, so you may want a bit more if you’re worried.
Thanks for sharing!
