Our team was looking at building a full set of Reef Scoring Pipes, but found the cost prohibiting and time consuming. This led us to trying to come up with an easier and cheaper way build it.
Here is our 3D printed Hub to connect 1.5in ABS pipes. It allows you to connect the ABS pipes together, but also accommodates the L2 and L3 scoring leg at the 35deg angle. We are using standard 45deg elbows from the supply store to create the offset for the L4 pipe.
The ABS pipes are slightly larger in diameter at 1.9in compared to the 1.66in diameter that we will see on the field. However, we feel that this difference is worth living with.
An individual Hub takes just over 3 hours on our Bambu X1C and a plate of six is approx 18 hours. Each one uses about 90g of filament. Printed with minimal support.
Here is the link to the files: Reefscape 3D printed Reef Hubs
