I’ve been playing around with making my own 3D printed treads for the REV Max Swerve aluminum wheels. Reason? The stock rubber MaxSwerve wheels have a short live, and the aluminum wheels have a smaller width than the tread you can buy on many websites.
And if it’s white tread, we can drive the robot in the hall with no carpet… without leaving visible markings.
There is already a thread for fully printed wheels, and treads for the plastic hubs:
And there is a thread for 3D printed wheels and treads for the SDS wheels that I posted to before:
I think making a dedicated spot for my stuff was in order. And for any general projects people are working on.
So… I started with these treads, Printed in Overture TPU (90A I think). There was some wall separation, but it looked fine for testing. Students installed them and said with the bolts tight the treads were misshapen and oval. Driving around was very noisy.
Since the team was busy with other things, I decided to pause work. Recently I added recesses for the buttonhead bolt heads. I printed one up and it seems to fit perfectly.
we’ve seen some great success with printing the tread as a closed circle that is 2% smaller than the diameter of the aluminum hub (4" wheel) and stretching it on, especially just if you are using it for driving on the gym floor or around the hallways it should be fine. It has entirely removed the need for bolts, though we might add a but of hot glue next time to keep the tread in place. you will have to cut the tread off if you want to replace them because they sit too tight once they get on, but installation is a breeze.
Yes. Team 4738 showed them to me at Beach Blitz. Figured I’d try to make use of the wheels we already had for testing. May upgrade to the wider wheels in the future.
I’ll have to check out your wheels too. Need to get some PETG filament.
Some long overdue updates!
Got all four treads on the robot and (after a lot of wiring troubleshooting… not sure what happened after Beach Blitz) did some testing.
Students drove the robot fairly aggressively on the tiles in the hallway for about an hour to check for visible scuffing or marking, and it was pretty “clean”. You could see scuffs where the robot slid around some, but you could rub them off with your shoe.
Then they went to town on the cheap non-frc carpet in our room. The carpet faired less well than the treads.
Definitely some wear. The peaks are less peaky, and the driving seems to have applied a fillet to the edges. The main reason for printing these was to have wheels we could drive in the hall without carpet. The students think that the treads, in this current version, would be good for one day at competition. May do some more testing with better printer settings, and different TPU, but I’d say these will serve their main purpose. We’ll likely also buy the Thrifty wheels and 1in neoprene for comp.
Note: the layer separation seen in the picture is how the treads looked right off the printer and did not get any worse.
