3x NEO Gearbox
Well the NEO has been out for about 8 hours now so I decided it’s long over due to have a dedicated NEO gearbox (even though it mounts the same as a CIM).
Currently it is geared 4.5:1, most likely will be changed later since on a 4" wheel it comes out to about 16-17 FPS loaded. I will most likely pocket the plates, but this CAD model is currently missing still the bolts and shaft spacers. Not sure how well the pictures show it but the center motor output shaft is supported by a bearing since the shaft is being double loaded. I’m currently planning to mount this on a chain-in-tube setup.
CAD: https://drive.google.com/open?id=1l_A1YCJK3Y2-AKWPFMJKUjjFSrr94zzR
Looks nice…also a note that we really need to release a CAD without the wires…
It looks realistic to a good number of teams’ wiring now though
If you do that, please at least leave the part where the wires connect to the motor, that way when people are designing gearboxes they don’t inadvertently design the wire outputs into impossible positions.
