I am planning on doing a 4 motor drivetrain with the SPARK MAX VIs similar to this picture. Can you find a way to modify it?
I believe the same code snippet for SPARK MAX would look like this:
You can modify it to use 4 motors instead of 6 just by removing those your team does not need.
I used the example located in the SPARK’s VIs palette: WPI Robotics Library > Third Party > REV Robotics > SPARK MAX > Examples. I recommend you explore what the API has to offer
How can I use it with the Open 4 Motor VI?
