4 vs 6 wheels (what to choose)
I’d say 6 wheel rocker. With the rock you don’t have to worry about “skipping” during your turns.
I second this idea. 6wd with the center wheel dropped 1/8 of an inch, and if you are using the kit frame the center hole is already dropped 3/16 of an inch.
“Cons: Lacks ease of maneuverability”
We actually did a test, and realized that the 6-wheel drive is actually more maneuverable than the Mecanum. :yikes:
I will agree with the others: 6 wheel drive.
Not true. My team had a four wheel mechanum drive train last year and it was really fast in every direction. However, it is true that going straight is faster than going in a different direction.
I would say mechanum because that is what our team is using and it works really well but the 6 wheel has really go maneuverability too if you implement the drive system right.
If you use 2 rubber wheels for friction as the two center most wheels and then you use omni wheels for the front 2 and back 2 then you have great maneuverability and better control. However you aren’t as maneuverable as with mechanum.
With the six wheel drive train, you have a better resistance from being pushed. My experience shows that the mechanum can be pushed if you have a weaker but faster gear ratio.
Hope this helps :slight_smile:
IMO, mechanum is a difficult task in programming during the build season, even for very experienced teams. Stay within your capabilities. Wheels are available through AndyMark, so the mechanical requirements can be met if you have the funds. Use the offseason to develop new systems and concepts. I have been in this fo 16 years, and am still learning. Just my opinion.
You can’t strafe with 6WD, you have to tank drive, which if hanging pegs, involves backing up, then turning, then going back.
Not if you align to the pegs while approaching them, and not after you hit them.
Many people around here seem to be saying “oh, oh, a mecanum is sooo much more maneuverable, omg” when a well-driven 6wd can do everything except strafe, and is easier to build since everything comes in the KOP (and slightly easier to program, although the WPIlib has mecanum code for you)
If you are within about a foot of the peg, which any respectable driver will be able to do, you can just turn in place and that’ll fix any misalignment…
My team is trying out mecanums for the first time this year… mostly because we thought the wheels looked really cool (joking). But really, I’ve seen a few threads on this forum about 6 wheels vs 4 wheels and I think the problem is that we need to define what maneuverability is once and for all for the purposes of FRC robots. If maneuverability includes strafing then obviously 4 wheel mecanum drive wins, however if u say maneuverability is the ability to have as much control over the robot as possible and get from one point to another as fast as possible and with control and you exclude strafing then the six wheel drive system would be more maneuverable (provided you have some method of preventing the front and/or rear wheels from skipping). All drive trains have they’re pros and cons and it comes down to your knowledge of the different type of systems, how you plan to implement the system and your team’s strategy for the game.
Maneuverability should be expressed as a quantity of degrees of freedom and the respective qualitative measurements for each. Each degree of freedom is either translative or rotational. Translative measurements should be rated based on acceleration and breaking, in terms of the length (distance) and/or time required to get up to maximum speed from a dead stop, and to stop from maximum speed. Rotational axes should be rated based on angular velocity, and minimum turning radius.
Maximum translative speed is irrelevant to maneuverability (in my opinion) since maneuverability is about controllability, not speed. Acceleration, on the other hand, provides information about how much space and time is required to change directions, which is directly related to controllability. Angular velocity is important since a robot that turns too slow wouldn’t be able to react quickly while one that turns too fast would be hard to control.
Even with these measurements, there are still so many factors that are unaccounted for. These really need a little more work.
No joke… that’s why we did it. We thought it would offer benefits in “the last tube game” and it did offer some benefits, but at far too high a price.
Where it really paid off was in the experience the team got, and the amazing videos and machine that we were left with afterwards.
Four years later and the wheels are still really cool.
Jason
If you want manueverablity with good wieght ditributation i would recommend 6 wheels with either tank drive or skid steer::ouch::
Driver practice has a lot to do with how “maneuverable” either drive platform really is. Getting something put together NOW and on carpet and connected to a working control system might turn out to be a reasonable priority.
Also…designing this year’s chassis based on last year’s game might not be the best thing to do. Last year was really weird, this year things are back to normal–the kit chassis is plenty strong for a flat playing field.
Nowhere in the OP was “mecanum” mentioned. I believe the question is 4wd tank vs 6wd drive tank. I’d go with 6wd tank as it comes well packaged in the KOP c-base. If you decide to go 4wd have two of the wheels be slick or omni wheels, so that your robot can actually turn.
Good luck!
in all reality both of these have strengths and weaknesses however the way you go about your design ie: tank, omni, mecanum, swerve, crab will really determin which set up along with what you want it to ba able to do ie: manuvure, agility, strength, pusshing power, etc etc etc however it seems alot of teams have had success with a 6 wheel drive using 4 mecanum and 2 sticky wheels however its all up to how u want your robot to perform
Surely you mean omni wheels? I’ve never seen a 6wd robot with 2 traction wheels and 4 mecanum, nor have I ever heard of one.
I may sound picky, but there is a big difference between a mecanum wheel and an omni wheel.
One of our Mentors, Clem McKown, created a PowerPoint in regards to drive trains models and it may help you with which drive train to choose.
A huge part of picking a drive train is what you want it to do and how you plan to build around it. Last year we wanted to build a goalie-bot. We decided quickly that we wanted to have the robot oriented so that we could block with the wide side. We then decided that a wide kicker would be a good idea. For this design mecanum was a just. we wanted to be able to drive really fast between the two goals but also strafe forward and backwards in order to drive up to the ball in order to kick.
For this year if you are confident that your programmers will be able to write line tracking code that will get you in position to score maybe you go with a 6 wheel rocker.
If you think you will end up manually positioning the bot to score then you have a bit more to think about. On one hand you can spin a 6 wheel rocker to make adjustments (to a certain point) while mecanum will easily strafe to do the same thing.
There isn’t really any way to say which one is better. It depends on what you are trying to do and how you are trying to do it. Thats what makes this engineering.
~DK
