We are a rookie team and trying to set up the PDP. We are almost done, but we are having some issues putting in the 40 amp breakers. Where are the wago connectors to put them in?
40A breakers are simply slotted into the top, as shown in Screensteps.
The Screensteps document has occasionally not opened for me, so here is the example.
The breakers are bladed and sit Between the Wago connector used for your motor controller wires…
In the photo you will see staggered slots that the breaker will go into.
One slot will have the green number corresponding to the Wago connector it will be protecting.
The 40amp breakers will only fit in 8 . Numbered - 0,1,2,3 and 12,13,14,15
