At our first regional last week, our robot appeared to brown out several times during matches, but the battery voltage never dropped below 10V. After looking at the data log in the driver station, we discovered that we were having anywhere from 20 to 40 brownouts on the 5V rail per match. We’ve checked the wiring and breakers, but can’t seem to find the issue. We have 3 encoders, a nav-x MXP, a USB webcam, and several PWM’s connected to the roboRIO. What might be the issue? Could there be a problem with a motor controller or an encoder, or do we need to replace the roboRIO?
The voltage drop can occur so quickly that a human can’t see it at the driver station.
Our team has experienced this before, and learned that the drive system transmission ratio must be matched well to the expected driving behavior - or very rapid dips of multiple volts can occur especially in case (b) above. If it’s too late to change the transmission ratio, the workarounds are (a) train the drivers to avoid quick direction changes and (b) ensure you have a fresh battery (>13V) before a match starts.
I doubt you’d exhibit any brown-out symptoms for main system voltages above 7v. At least we don’t!
Things to check:
-All 5V connections (no tinned ends in the spring terminals!)
-Frayed wires that could short around the spring terminals
-Loose mini bussman fuse (they need a lot of force to seat)
-a 5v device with a grounded body (not uncommon) might be shorting somewhere
Does the RSL light stopped blinking, then start back up? that is a sign of processing stoppage.
Last year our team did not properly crimp the battery cables. The cables were also under tension. It was my first year working with FRC teams. The senior student programmer told us it was a software glitch that caused the program to stop, (RSL light stopped blinking). No, it was a brown out.
This is the most likely culprit. We had the same problem at the Dallas regional, which turned into a full blown short. Had to pull the Rio out, take it apart, and clean it out. There were a few bits of Al rattling inside, and it sorted the problem out.
A little additional technical info regarding the other suggestions though:
The only 5V rail that you can monitor is the one that the Rio generates internally from the wide Vin input. As such, if the other rails are fine, then the power going into the Rio is likely fine as well. All of the PWM outputs are 6V as Al alluded to, so there isn’t an issue with the motor drivers. Your GPIO pins and MXP port are the most accessible 5V output, but the USB port and other comms ports are open to shorts as well. It’s worth using something to cover all the gaps to keep scrap metal shavings where they belong (outside the Rio).
