This year, we really like our 6 wheel drive. We wan’t to improve it for next year, including increasing performance in general, and by maybe adding some extra features.We had some questions about these features, if anyone has used these before, including:
2 in thich Wheels
Is there a notable increase in turning scrub?
Is the increased traction noticable? In what ways?
Have you found that it improves your defensive/offensive performance?
Drop down casters
(I heard that 987 has done this previously. Correct/incorrect?)
How effective is it at getting out of t-bone pins?
Drop Down Outer Wheels
(I heard that 469 has used this previously. Correct/incorrect?)
Have you found that it imroves your offensive/defensive performance?
Obviously, in qual matches, these would most likely have little to no effect on performance. But in elims, it seems like there could be a significant improvement in performance.
About you question in wheel width, this topic has been discussed a number of times, with different answers. For us we have noticed that while our traction seems to be about the same, our tread seems to wear better with a wider contact patch. It’s for this reason, and the amount of space they take up that we settled on using 1.5" wide wheels.
There are a ton of options out there in terms of wheel options, and even more for tread material. I strongly suggest exploring them.
I am confused on this. Can someone explain why having drop down casters would help with defense? Also, what do Drop Down Outer Wheels provide? Some pictures would help if possible.
It changes your center of rotation allows you to spin about 2 outer wheels rather than the middle wheels. This prevents you from getting t-boned by allowing you to spin out of it.
Traditional Skid Steer Drive trains are very susceptible to ‘T-Bone’* pins. Because Most Skid Steers rotate around their center, or somewhere close to it, they cannot simply spin out of the pin - if you draw a simple sketch, you’ll see that while you’re rotating one end of your robot away from the defender, you’re also rotating a side into the machine.
Dropping a caster/omni-wheel/skid on one end helps to move the pivot point of the drive to the opposite end, which allows the robot to simply spin out of the pin.
*T-Bone Pins usually refer to an instance where a robot is hit perpendicular to it’s drive train’s motion - these usually happen on open field, essentially pinning a robot without needing a wall/object.
I’ll make a plug for WCD (“West Coast Drive”) here. The concept of the frame setup, wheel blocks, live axles, cantilevered wheels and tensionless chains all cobmine to make it a great, versatile drive setup. Our team will do this next year since we proof-of-concepted the first sliding block in March. It took 2 hours to make the block on a manual mill, but we feel confident we can get that time down.
WCD itself isn’t the answer to everything related to drive train – yet it is the one “baseline” drive train that allows for the most design adjustments (# of wheels, wheel diameters, wheel types, tread types, which gearbox, etc) in the least amount of time. Adding extra features (like a drop-down caster/omni) is very easy as well.
Hollow tubes make for great axles, These were tapped so that there were no collars on any of the drive axles, it also saved a ton of weight, we used .495 OD with roughly .1 walls.
Track width, our 6 inch performance wheels were less than .125 from the edge of the 28 inches, it made turning much more forceful.
Maximizing traction, blue tread from Master on 6 inch performance wheels has a LOT of grip.
Choosing the proper gear ratio, our high and low gears were 16.6 and 6.7 ft/s this is NOT traction limited in low gear, enabling us to push robots with lower gear ratios when they broke traction due to overzealous driving.
Drop down casters sound interesting, our driver never got stuck on other robots, but if he ever got close/parallel to a wall it was difficultly to quickly get UN-stuck.
Exercise caution in future years and apply the material for the year rather than using the “we always do it this way” way of thought. I’d be concerned that the outer axles would bend if it came off the bridge or bump incorrectly. Did you do any simulation or calculations to figure out the tensile stresses your axle could hold?
On a flat or predictable field like 2005, 2006, 2007, 2008, 2009, & 2011 this isn’t a concern.
As far as the width of the wheel, we on 973 noticed a big difference in traction with 2" wide wheels vs traditional 1" wide wheels.
In 2011 we used a wcd with 4" diameter, 2" wide weels, with a 3/16" center drop. The combination worked great. The drivetrain allowed us to switch from strict offensive play to strict defensive play with the ability to push every robot we came in contact with. Check out the cad for Titan in my signature. If you like what you see feel free to use our design(s) and pm us if you have any questions.
In 2011 team 33 had an 8wd with the back wheels able to articulate up/down. When they were down it picked up the back of the robot enough to lift the inner 4 wheels off the ground making it very difficult to turn us. When they were lifted up we were an 8wd that could turn on a dime.
What kind of wheels, and what kind of tread? And any reason for using 3/16 drop over 1/8 drop? Did you feel it had an advantage? If so, what was it? Any disadvantage?
My guess is that because they were using 2 in thich wheels, they had an amount of turning scrub that they didn’t like. By increasing the drop, they decreased that amount.
Watch this http://www.youtube.com/watch?v=mhtdko28dBo&feature=youtube_gdata_player video of us (45) and 111. We play defense so they cannot deploy their minibot. Interestingly enough, the T-Bone pin is crazy effective, and because we were soo good at pushing last year, they just could not get out of it.
Our drive was setup so that there was about 1/4 of an inch between the wheels and the bearing blocks. This allowed for the lighter axles, bending was never an issue, one match we even drove off the 24 inch drop made by an unbalanced bridge with no damage to the axles. Keeping the axles short was critical to maintain a robust system.
Edit:
We did test the axles on an our off-season WCD, they were flawless and bending was minimal. We beefed up the axle wall thickness a bit for competition to ensure they would never break.
The wheels are custom, we used blue rough top tread. The reason we went with 3/16" drop over 1/8" drop was to ensure better turning capability, less scrub on the raised wheel, etc. The advantages were that we could push every robot we came in contact with (even 469) without any fancy add-on’s and without giving up offensive speed. There weren’t any big disadvantages with the drive (the only thing that really gave us trouble was the 775 motors (which were removed before champs), if we use the design again we will use 550’s in conjunction with the 4 cims).
Though for the moment, emperor swerve is working great for us, so it may be a while before you see 973 using the drive train again.
