Hello Chief Delphi,
Recently, I looked at this kit in AndyMark and wondered, “So, my team has all these parts already, what are this design’s pros/cons?”
This is the configuration:
Omni wheel; standard wheel; standard wheel
More specific questions are:
This kit has the center wheel lowered by about 1/10 of an inch, would it be possible to eliminate the difference and still turn easily?
If the wheel axles were all in the same plane, the center of rotation would not rock/shift like a standard kitbot, right?
It would be possible to adapt a kitbot to use this concept, right?
Should I power all wheels?
Thanks in advance,
Daniel
) It was by far the best drivetrain we have made, and it was arguably better than most 6wd robots without omni’s. We DID NOT drop the center due to the fact that omnis have a slightly smaller diameter. You definitely should power all wheels in this case, even without a drop it is necessary. I do not think that It would be possible with a kit Cbase, as the center wheel is dropped. Just my 2 cents
