Here’s a video of our 2011 minibot deploy and climb.
Not the fastest bot yet.
KISS on the deploy.
http://www.youtube.com/watch?v=hvrbb9g9EHM
nice job!
check out our deploy/climb of ours!!
-stuart kaneshiro
team 1056
Please check the rules and the Q+A.
The minibot cannot be above the plane of the 18" line after it breaks the plane of the base of the tower. Hard to tell from your video about this.
Can you site a reference? I don’t interpret it that way.
Bruce
Sure.
<G21>
HOSTBOTS may DEPLOY MINIBOTS only onto their ALLIANCE‟S TOWERS and entirely below the DEPLOYMENT LINE. Violation: RED CARD. TOWER is disabled if MINIBOT is DEPLOYED above the DEPLOYMENT LINE.
<G21> HOSTBOTS may DEPLOY MINIBOTS only onto their ALLIANCE‟S TOWERS and entirely
DEPLOYMENT LINE
DEPLOYMENT – the act of positioning a MINIBOT on a TOWER. DEPLOYMENT starts when the
MINIBOT breaks the vertical projection of the TOWER BASE circumference. DEPLOYMENT ends
when the HOSTBOT is no longer in contact with the MINIBOT. (Related form, DEPLOY, verb)
G21 Alone does not make your deployment illegal, however since deployment starts at the instance the Minibot breaks the tower perimeter, your deployment would be illegal, if at any point in your arc the minibot is above 18"
Boy, read and reread that and still don’t interpret it that way. No one at todays miny regional had any issue with it.
Bruce
Draw a side view of the HOSTBOT and TOWER. Draw a horizontal line between them at 18" above the TOWER BASE. Draw a vertical line at the edge of the TOWER BASE. See if your any part of your MINIBOT is above the horizontal line, when it’s on the TOWER side of the vertical line. If so, you’re gonna get a RED CARD if an observant ref is watching.
Sorry…
http://forums.usfirst.org/showthread.php?t=16251&highlight=plane
http://forums.usfirst.org/showthread.php?t=16981&highlight=plane
I don’t necessarily read <G21> as prohibiting a host bot nor a minibot from breaking an imaginary plane at the height of deployment line as long as the hostbot nor the minibot is in contact with the pole.
Clearly, a host bot in contact with the pole above the deployment line, or a minibot in contact with the pole above the deployment line before the minibot has separated from the hostbot, are violations of one or more of:
<G20> ROBOTS/HOSTBOTS may not contact their own TOWERS above the DEPLOYMENT LINE. Violation: PENALTY for contact.
<G21> HOSTBOTS may DEPLOY MINIBOTS only onto their ALLIANCE‟S TOWERS and entirely below the DEPLOYMENT LINE. Violation: RED CARD. TOWER is disabled if MINIBOT is DEPLOYED above the DEPLOYMENT LINE.
<G22> HOSTBOTS may not contact their ALLIANCE‟S MINIBOT while any part of it is above the DEPLOYMENT LINE. Violation: TOWER is disabled
Chris Fultz interpretation “The minibot cannot be above the plane of the 18” line after it breaks the plane of the base of the tower." is just one potential interpretation of the rules. ** I would suggest Bruceb pose question to the GDC. BUT…
Correction (thanks Vikesrock): the GDC already ruled…and the vertically swinging minibot deployment in which the minbot breaks the deployment line imaginary cylinder is a violation.
http://forums.usfirst.org/member.php?u=33258
I think the deployment shown in the video meets the intended spirit of the rule and the field judges will have enough of a problem with monitoring for violation of <G21> when a pole contact is being made. I doubt most field judges would want to trust themselves to measure an imaginary cylinder at exactly 18". Will we see a special measuring tool?
Perhaps the refs or inspectors can ask you to demonstrate that the MINIBOT is entirely below the horizontal plane after DEPLOYMENT…that should be possible before/after a match?
I’d like to see the alternative interpretation, how does it work?
SO do the rules mean that at no part of the minibot deployment(when your hostbot moves the minibot into position to climb) can your minibot be above 18in.?
Post #8 in this thread by Squirrel does a great job of describing the rule as interpreted by the GDC in the Q&A
Well, G21 says
G22 says
Deployment line is defined as
DEPLOYMENT LINE – located on the POST, approximately 18 inches above the top surface of the BASE.
LOCATED ON THE POST there is no reference to a plane here or anywhere. It is a line on the post so my interpretation is that your hostbot cannot touch the minibot while it is on the tower post above the DEPLOYMENT LINE.
THe deployment line does not exist anywhere but on the tower post.
Bruce
Bruce, that unfortunately disagrees with what the GDC has ruled in the 2 Q&A posts I linked to. I would recommend posting your reasoning to the Q&A for additional clarification if you are hoping to stick with your current design.
I see now how you interpret it. Thanks for the explanation.
The deployment line makes a horizontal plane, even if that plane is not explicitly mentioned in the rules.
You can try your luck…please let us know how it works out!
Alternative interpretation…
(I wrote this over the past hour while I was watching television and did not see Bruceb post which made basically the same argument)
Defined terms in the rules:
DEPLOYMENT – the act of positioning a MINIBOT on a TOWER. DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference. DEPLOYMENT ends when the HOSTBOT is no longer in contact with the MINIBOT. (Related form, DEPLOY, verb)
No where in the manual does it define a cylinder of extending from the deployment line.
Elsewhere in the manual, it describes cylinders for violations but not for this case.
My copy of the rules from Jan11 did not have this form of deployment as a violation. This violation was added in Update #2. The GDC decided to change instead of just changing .
(They also did not add a cylinder explanation for this changed rule).
The spirit of the rule is the minibots need always remain completely below the deployment line while in contact with both the hostbot and the pole.
And that, at first contact with the pole, the minibot must be completely below the deployment line.
Do you really think the GDC specifically wanted to preclude this type of deployment? I think it is just that it was they just used the fewest words to to make up for their omission that the minibot needed to start completely below the deployment line. Maybe they were concerned about minibots very close to the pole and still above the deployment line and the potential difficulty it would cause to referees making a ruling.
BTW, my team doesn’t violate this rule: we move our minibot horizontally.
There are at least a couple good lessons here:
- Read the rules and the updates AND all the GDC Q&A
- Post your progress here on CD and get good advice BEFORE you get officially inspected and get surprised
Writing requirements and manuals is usually a thankless job. The GDC does an excellent job. Bruceb and team have days to create an alternative deployment if Q&A does not work for them.
It’s really nice that everyone is willing to be helpful.
Here is the link to the GDC ruling on Jan 14th.
Question:
The definition of Deployment states that DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference, and ends when the HOSTBOT is no longer in contact with the MINIBOT.
G21 states HOSTBOTS may only DEPLOY MINIBOTS onto their ALLIANCE‟S TOWERS and entirely below the DEPLOYMENT LINE.
May the MINIBOT be above the plane of the deployment line after the start of deployment, provided the MINIBOT and HOSTBOT are below the plane of the deployment line at the end of deployment and no other rules are violated (i.e., touching the post)?
In other words, does the deployment line create a plane that cannot be exceed by the MINIBOT from the start of deployment until the end of deployment?
GDC Answer:
No.
Yes.
Alright alright. We spend 4 hours today to basically invert our deployment mechanism. It now swings from the top and the minibot NEVER is over 30 inches from the floor.
Video to follow.
Bruce
Finally got a video of our initial test of our new deployment system.
It’s a lot faster now but you get the idea.
http://www.youtube.com/watch?v=NshePgWQORM
I think this is a legal configuration. The mini is never above th 30 inch line.
Bruce
btw thanks for the feedback on the other deployment system.
