842 belt test
We used poly cord before in other years, but we are looking at belts this year.
I like it.
I like it as well. I would probably put the driving motor above the actual system and sprocket and chain that to an assembly that runs the belt so the motor doesn’t put so much stress into it. I also would extend the belt drive to a 90 degrees angle down as close as you can the the bumper zone on the edge. That would be one hell of a lightweight ball collector.
Now I am rethinking our choice to go with polycord. Any specific reason you went with belts? I would think you would have less stress on the motors since you dont have to stretch the cord too much. The only down side I can think of is that is a fairly small width collector. Of course, there are always tradeoffs…
You could use multiple belts. We figure for the elevator part of our robot we can get away with one
Was that the main factor for leaning that way? Belts are super effective, just wondering what your particular reasons were.
Looks nice.
-Brando
We’ve built many a robot with timing belt based ball handling mechanisms with great success, so you’re on a good path IMO. Your mechanism looks solid from my seasoned eye, keep up the good work!
We are looking to return to the kind of belt system that we used in 2009, but scaled down two feet tall and two belts wide. That elevator was so beautiful, and SO FAST. The time from grab, to alignment, to shooting is no more than four seconds.
