Would be interested in the following measurements:
-ID of 9 tooth pinion (if you have any remaining untracked ones), probably measured by the back end of calipers assuming a set of pin gauges is unavailable
-OD of NEO output shafts, micrometer would generally be most accurate, but could also use same calipers from gear ID
-OD of a normal CIM output shaft, keeping consistent with measurement technique for NEO motor
-If you (or anyone) happen to have the Thrifty Bot falcon CIM shaft replacement, it would certainly be interesting to compare OD measurements as well, though might not be quite as relevant to these particular gears cracking
With press fits like this, thousandths and even ten thousandths of an inch will impact how the parts interact. The various suppliers of different “CIM style” standard shafts may ride on different sides of the tolerances (e.g. supplier A is a few ten-thou too big, supplier B is a few ten-thou too small, and the difference stacks up to half a thou, and cracked pinions!.. just a possible explanation, unsure whether it would hold true).
May be worth reaching out to suppliers and discussing with them, but having these types of measurements handy may lead to more productive/fruitful discussions. Also worth providing possibly, the method for pressing them on? Arbor press?
I also noticed from the image on the VexPro website that the wall thickness near between the teeth of the 9 tooth pinions looks rather thin. I’m sure a true designed dimension could be measured in CAD though.
If it were me, I’d need a pretty darn satisfactory answer and solution to endorse risking implementation of that particular gear plus motor combo on my team’s bot. I had been hopeful for the possibilities offered by these smaller pinions, and more powerful motors, but maybe it’s not a readily obtainable reality quite yet.
Spring boarding off of @xnated’s sanding the shaft idea, reaming or drilling larger the gears themselves could work…but that might also make the part that’s cracking even thinner.
So I’d probably lean toward the sanding idea.
