Update 4: No Pain, No Gain
We started building the robot this week. Assuming we stay on schedule, our next post will be a robot completion post.
Monday
Not too many people showed up today, so we just worked on getting Photonvision installed on our two Raspberry Pi 4s
Tuesday
Tuesday was a big day for us. We started by cutting the linear actuators to length and drilled holes in the crossbeams so that we could mount them to the frame later on. Our SPARK Flexes and NEO Vortexes arrived, so a few other people spent some time testing those and making sure they worked. Finally, our mech lead started cutting our indexer tubing, at an angle. (idk he told me to mention this but idk how it’s relevant)
Wednesday
We had an early release today because of county-wide professional development, unfortunately, it meant we weren’t able to meet.
Thursday
A few people started by test-fitting the crossbeams into the frame and making some adjustments. After we were sure that they fit, we mounted our linear actuators to the crossbeams and wired them up for quick testing. After we did that, the rest of the meeting was mostly spent debating as to what shirt color we should get. Since we didn’t want to use the same color as last year’s design, it took us quite a while to figure something out.
Friday
We had a lot to do today and very few people. I started by going to grab our machined polycarbonate plates from 5549 (thanks guys!) and an extra MaxPlanetary base kit from team 611 (double thanks guys!). While I was gone, a group of people were countersinking our motor plates from Thrifty Bot. Once I returned, we got working on mounting our 90-degree gearboxes and motors to the linear actuators. We then took out the crossbeams because we realized that we’d need to get the hex shaft put in later.
Saturday
This was a huge day for us. Probably the largest progress day we’ve had in a while.
We started by testing the linear actuators with the added weight of the new motors. You can see the video of that test here. Once we confirmed their function, we started riveting our indexer plate. We used these new rivets that were massive and it took us a while to get all 4 in. Once that was riveted together, we put on our bottom shooter plate and hooked up the motors to test. (Peep our gorgeous test wiring here). Our tests started out, uhh, not good, as we totally had the motors inverted on each other and it nearly snapped our polycarbonate plate. Watch the moment of pain here. After that catastrophe, we took it slow, and tried a few more times. We quickly realized that we accidentally had the motors inverted, and after that, we tried again to much more success. After some more tuning and making sure everything was working, we finally got to this point, which was the end of our meeting for Saturday
CODE TIME:
Here is our public code, while it has been public all season, we now feel comfortable enough to share it with y’all on here: GitHub - Ocebots/ocebot-code-2024
Overall, we got a lot done this week. Hopefully, the bot will be done next week, but I can’t make any promises.
