A warning regarding MPLAB and find/replace
We found out the hard way today that MPLAB does not respect the highlighted area when you use the find/replace command.
We had to change a couple terms, so we highlighted the section and used the find/replace command.
Unfortunately, 15 minutes later (and much coding) we discovered that it replaced ALL those terms through the entire program.
Yuck.
