How does one account for possible friction loss when designing a mechanism?
I am building an acquisition unit using the small dead axles design similar to this: https://www.chiefdelphi.com/t/how-do-these-254-mechanisms-work-bearing-retention/409093/14 .
I have 4 3D printed pulleys, 8 bearings (two in each pulley). 2 timing belts, one a 2:1 reduction the other a 1:1 ratio, so more than half pulley wrap on the one pulley and half pulley wrap on the 2 1:1 pulleys. Belts are properly tensioned. I also have 2 2" polycarbonate tubes 10 inches long to complete the acquisition.
No obvious friction such as pulleys scraping sides, bearings not centered, etc. The motor (non-FRC approved motor) is calculated to do the acquisition work assuming it isn’t using all of its power just to turn the rollers.
I am pulling 1.5 amps just spinning the motor and the one pulley connected by the 2:1 timing belt reduction. Adding one polycarbonate tube makes it jump to 2.5 amps. Everything connected together but not grabbing the game piece pulls 5 amps.
All of this means I am on the wrong side of the motor curve and not achieving the speed I want the acquisition to run.
I am not a mechanical engineer. I can put a bigger motor on it, but I am trying to understand why all the energy loss in the mechanism. Any thoughts on what I did wrong?
