Hello All,
I have been prototyping a deferential swerve module and have run into a bit of a snag. I am using press-fit acetyl spur gears for convince. I trimmed part a spur gear’s hub length for space constraints, this of course limits the amount of friction on the shaft and the gear could slip. I could try to use loctite or various adhesives for working with acetyl, Delrin, HDPE, etc but I would prefer not to. A cross-hole & pin in the shaft is also not an option.
I was not able to source a bearing with the required ID and OD for the spur gear hub and gearbox plate respectivly, however I was able to source a bronze bushing that will work with my space constraints (if this was competition hardware I would redesign the plates to accommodate a proper bearing). Here lies my question - What lubrication (if any) would be required for acetyl-bronze contact?
Additional info:
Shaft diameter: 3/8"
Shaft max RPM: 950 (free)
Axial load: Minimal
Radial load: Minimal
