I am from Team 3270 and i am a new programmer for the team. I wanted to know how to add code I made and put it into the robot main.vi so that i would be able to execute it. I tried to execute the code by itself in the developer station but nothing will happen and when i tried to add it through copy and pasting it, it did not work.
This reminds me of the year someone posted that they were missing the assembly manual in the KOP!
If you are just beginning to use Labview, I would suggest you go to www.frcmastery.com where you will see some great examples that will answer your questions.
I would further suggest that you start by using the examples provided. You can program a fully functional drivable robot with just those examples. Then, you can start using the template. I hope this helps.
