Adding a Talon SRX to begin.vi in Labview
I’ve been trying to add a Talon SRX to our robot to use an encoder. I have only found where people have used it on the drive motors but I need it for a lift motor. I’m sure it’s simple but I just don’t know how to do it.
Go here… scroll to the first tip…
https://phoenix-documentation.readthedocs.io/en/latest/ch06_PrepRobot.html#verify-the-robot-controller-labview
…or look at our many examples…
https://github.com/ozrien/Phoenix-Examples-LabVIEW
Make sure you set your device ID to match what it is in Phoenix Tuner.
Make sure to follow the instructions in order on https://phoenix-documentation.readthedocs.io
could you elaborate because using for a drive and for a lift should be pretty similar in labview
do you mean the DriveMotors.vi?
