Additional Support on the Stage
Is there any potential to use the area or boarder around the Trap scoring area for support so a robot can score?
I don’t think so because it says that anything besides touching is prohibited for things that aren’t the chain. I believe you could rest against it if you want to prevent swinging but you couldn’t hang on the trap opening.
What about rollers on the each side of your trap scoring device? That would help to stabilize but not grabbing, grasping, attaching to entangled or suspending from. I am thinking you could pivot your robot to hold the trap open to score if the rollers were there to push against and change the angle of your trap scoring device.
That should be allowed. My team is considering something similar
Our team is considering having a react climb where we lean against the stage under the flap for stability
