Advantage kit "Buildconstants" issue
When attempting to build 6328’s example advantage kit code, an error stating “buildconstants cannot be resolved to a variable” pops up.
This issue also pops up when attempting to load up 2023 robot code from 6328 and 3476, both of which also have the error “buildconstants cannot be resolved to a variable”.
Image example from 6328’s example advantage kit code:
Is there a class or enum that I am missing?
Is it just red squiggles in vscode, or do you get an error while actually compiling?
That class is generated at build time, so the IDE won’t have anything to find until youve compiled at least once.
It was red squiggles in vs code. Apparently in all the times I loaded up the code I forgot to run a build on it.
Building the code solved the issue, thanks for the help!
