ADXRS300EB gyro help
I am wondering if any one can confirm the pins for the evaluation board is pin 1 = power, pin 2 = rate out and pin 8 = ground. I tried using the default code and only change was the gyro selection. I am getting no gyro rate in the terminal.
Kevin’s default gyro code is set to analog 1 - make sure your gyro is connected to analog 1 unless you have changed it in the code.
It is. i get a rate sometimes but never higher than five
Did you connect AVCC (pin 1) to PDD (pin 13)?
-Kevin
Thats a negative. didn;t know you had to do that, thanks for the info!
