Air Pressure Question
Hi!
Is it legal to connect two regulators and two solenoids to one piston? See attached .png.
4.10.17 R90
The outputs from multiple valves may not be plumbed together.
So that is a no on the multiple solenoids. You would have to use multiple pistons to use multiple solenoids.
Thanks Trent! Guess we’ll use a back up plan.
  • Kapua
We were looking into the same question/rule,
What is your plan B?
One idea thrown out was to run a Parker valve with a servo. Don’t know?
We ordered a smaller diameter bore, as we are using 1 1/2", 9" shaft to work with while the 1 1/6" makes their way to Colorado.
Thanks!
