Air Tanks
I was wondering are we allow to buy four Clippard air tanks and four 2" broe air cylinders?? And Does anybody knows where to buy the fitting for pneumatic and Tubing give a web sit if possible
thanks
In the pneumatics manual, there is an order form for ordering additional cylinders at no charge. Beyond those extra cylinders, you are basically stuck with what came in the pnuematics kit(i.e. no buying any more valves or air tanks)
I thought only Parker and Bimba equipment is legal anyways…am I missing something?
You can only use what was in the kit and up to 4 additional cyls using the order form in the back of the pneumatics manual.
Nothing else… Sorry…
Mike
Thank you for helping me out
:slight_smile: :slight_smile:
Are we allow to buy the air cylinder from our local company like KPM???
Nope. The only pneumatic sources that can be used are the ones that came in your kits and special order cyl. down to the EXACT partnumber.
Neill
Team 933
oops…if the mfg and the part numbers are EXACTLY the same, then you can get from a local source.
*Originally posted by Mike Betts *
**You can only use what was in the kit and up to 4 additional cyls using the order form in the back of the pneumatics manual.
Mike **
That’s what I thought, but team 60 insisted otherwise at the SCRRF scrimmage.
