Aligning while driwing
Hi. i have been trying to figure out how to auto align to the speaker while the driver is still moving the robot. basically i am trying to change the rotarion of the robot so that its perpendicular to the april tag at any time. i have had no luck with this. does anyone have an example code or can help me figure it out?
What type of vision are you running?
If you’re using Limelight, get the ‘tx’ value from the Limelight data to set your ChassisSpeeds omega, sort of like a P-loop
we are using photonvision. Also we only want ids 4 and 7 to be aligned to (depending on the alliance) any idea how we might do that. im kind of a photonvision beginner
Not very familiar with PhotonVision, but I found a documentation page:
It’s a good idea to read it to know what it’s capable of. My guess on how to do it is: iterate over the list from getTargets(), check each target’s getFiducialID(), and if it’s 4 or 7, use the target’s getYaw() to run a P-loop.
another question, what do you mean by a p-loop? just a kp loop?
Rembrandts has a very good post on using coordinates to do this: FRC 4481 Team Rembrandts | 2024 Build Thread | Open Alliance - #373 by Jochem. Essentially, if you know where your robot is and you have and an x and y coordinate that you want to aim to, you can do some simple translation math. I would recommend combining photonvision with odometry to get a pose estimate of your bot location. Have you looked into SwerveDrivePoseEstimator at all? I recommend reading this: Pose Estimators — FIRST Robotics Competition documentation (wpilib.org). Also, take a look at the photonvision docs on how to use AprilTags for localization: 3D Tracking - PhotonVision Docs.
Here is a code snippet of how our team handled aligning to the speaker. We used PID to control the angular speed and let x and y speeds still be controlled by the driver.
public Command alignWhileDrivingCommand(Supplier<Double> xSpeed, Supplier<Double> ySpeed, Supplier<Translation2d> target) {
    PIDController pid = new PIDController(0.01, 0, 0);
    pid.setTolerance(1.5);
    pid.enableContinuousInput(-180, 180);
    return new DeferredCommand(() ->
      new RepeatCommand(
        new FunctionalCommand(
            // Init
            Translation2d currentTranslation = this.getPose().getTranslation();
            Translation2d targetVector = currentTranslation.minus(target.get());
            Rotation2d targetAngle = targetVector.getAngle();
            double newSpeed;
            if(DriverStation.getAlliance().get() == DriverStation.Alliance.Red)
              newSpeed = pid.calculate(this.getGyroYawDegrees() + 180, targetAngle.getDegrees());
            else
            this.drive(xSpeed.get(),ySpeed.get(),
            newSpeed, true, true);
              interrupted -> {
                pid.close();
                this.drive(0.0,0.0,0.0,true,true);
                return pid.atSetpoint();
              this)), Set.of(this)
For reference, here is our github repository: FRC1884/season2024 at testing-1884 (github.com).
I highly recommend taking a look at our PoseEstimator.java and Vision.java classes.
We do have a photonvision pose estimation code that works
Perfect, that should make things even easier for you.
