AmboVent | Design review for COVID-19 ventilator!
TL;DR
Led by Israeli FRC teams 1690,1577,2231 & Unit108 of Israeli Air Force:
AmboVent is an open-source, low-cost, medically tested ventilator device, made from off-the-shelf components, to answer worldwide shortage.
  • WE NEED YOU!
    AmboVent’s blueprints has just make public, and now we need assistance from the amazing FIRST community:
    Teams need to analyze and attempt to build prototype versions of the AmboVent immediately, in order to assure that the documentation is complete and independently reproducible.
Additional Information:
Demonstration of AmboVent:
AmboVent is currently valued among the two best solutions, together with global medical-device company, Medtronic:
Earlier version of AmboVent getting tested in Ichilov Hospital:
Teams who attempt to build AmboVent, first of all, thank you.
Second, here are things that we want to hear from you:
  • How was to assemble the winch into the motor? Ways you suggest to improve it?
  • How was to assemble the winch to the arm? Ways you suggest to improve it?
  • Any more available alternatives instead of hex shafts & bearing?
  • Any other things you find relevant to assure that the documentation is complete and independently reproducible.
You can learn more about AmboVent:
We would like to thank to all the partners who contribute for this project:
Thanks,
@guy @kornblau @Korny @Sagi
This is definitely the furthest-along and most realistic set of plans I’ve seen. Props to the team working on it! Thanks as well for providing the numerous warnings, and asking for the eval (rather than jump in both feet first and start building/distributing, as some news agencies would want us to do…).
Although you didn’t ask for this,I wanted to provide some feedback on the embedded controls software (and am choosing to do this as a post, and not an IM, for audit purposes):
The Arduino is an excellent prototype platform, but will definitely be insufficient for maintaining safe operation. Safety Critical (medical included) devices generally will want some level of hardware-level redundancy and checking to ensure the controls are up and running. In addition, the main control loop is running “as fast as possible” , with telemetry and the pressure control loop at the same priority. Again, perfectly fine for prototyping, but you’ll want something more robust before you start pumping air into a human.
TI’s Hercules platform is one line of safety-critical processors that has the internal goodies required to ensure the code execution is still moving along nicely. I think it would satisfy your IO requirements as well. They sell a $60 launchpad module which, though not 100% drop-in with the arduino you have, would likely fit the bill. You’ll want to check their example code and docs to ensure the safety features are enabled, self-tested at power-on, and are applied properly to ensure the life-sustaining critical loop tasks are executing on time. Note this is in addition to your existing fault detection strategies.
Additionally, you’ll want to pair the new hardware with a real-time operating system that supports task prioritization and preemption (or, at least, some form of interrupt-based “this task needs to run now” concept). OpenRTOS is an option that can pair with that hardware platform. The key reason here is allowing your pressure control loop to be at a high priorty with a well-defined execution rate (20ms? 10ms? not sure…), while the telemetry, LED blinking, screen update, etc. tasks take a back seat.
Let me know if you’ve got questions - these aren’t the only options, just two I’ve happened to fiddle with in the past (abet in separate projects, never together).
Even using these, the device still obviously doesn’t hit regulatory requirements - but it would be much closer to what as an engineer I’d call a “safe” system for human life support. I’d definitely recommend having something to address the software/hardware solution on your roadmap going forward, if you don’t already.
Finally, and this is purely cosmetic: For ease of public audit, I’m much more a fan of K&R C style. But that’s a topic for another day.
All this being said, there is (as many others have spoken to) the liability question, which varies from country to country. I know in the US there hasn’t been a declaration of anyone-can-manufacture yet, which is fundamental restricting to teams without a legal department. Still, it is worthwhile being prepped if that ever does change, or requests come in from individuals you trust not to sue you.
EDIT: Again, I do really want to say great job! It’s this level of documentation and well-thought-out process and design that is useful for rapid iteration. Efforts like these are the ones that will concretely posture us to take on the great challenges we face!
First of all, I heard some concerns, so I want to be clear and loud:
1.Your products won’t be in use with humans!
We need your help to test the assembly process and to make sure that documentation is complete and independently reproducible.
2. AmboVent isn’t an home-made ventilator, the project involves Ichilov Hospital requirements and testing. Beginning of mass production (by Israeli Factories, not by students), is up to them and to final approvals by Ministry of Health.
Second, @gerthworm, thank you for the detailed response here, I’m encouraging more to to the same. For your question, probably @kornblau can answer, as he leads this part, and also was in the testing helded in Ichilov Hospital.
