Hi guys. I have an AMT103-V Encoder. I was planning to attach it on the encoder output shaft in the Toughbox, but I didn’t have any sleeves left. Can I print these sleeves with a 3D printer? Or is there a better solution?
3D printing would probably be fine as long as everything is centered properly and such. Though do consider the orientation you print your part in, and try to make sure the layer lines are perpendicular to the plane the stresses will be on.
