Analog Inputs
Hello all,
I have a problem, I don’t know how to get data from the analog inputs. any info. would be helpful.
You need to first wire it according to the manual (correct pins +5, GND, and the signal) Go to the initialization area and for the sensor you want to read make it CON 1. Then add the sensor you are using to the serin command (Sensor 1 and up). Presto you have the data.
email me if you have any problems
Matt
Check out this little tutorial:
How to enable the RC Analog Inputs
http://www.team188.com/cr/forum/technical/messages/51.shtml
