Are these legal? They are under the price restriction, but the stroke is larger than 1" (which seems to be the limit for a linear actuator). It will be a critical mechanism, so we need to know if we can use it or go with our current configuration (not using servos).
The 1" limit is for mechanical solenoids [electrical solenoid actuators]; servos are a different thing. The limiting factor on servos is the price (< $75). See the next-to-last row of the table in R34. (You were probably looking three rows up.)
If you’re still designing and don’t have the parts ordered/selected yet, you may also want to look at these linear servos: https://www.servocity.com/servos/linear-servos
Note that only the first four listed are legal; the others are priced well over $75.
– and be sure to consider the speed when designing as well as force and stroke!
