AndyMark Sensor 6PAK am-3220 at 3.3V?
I am looking at using the AndyMark Sensor 6PAK am-3220 for a non-FRC project.
Does anyone know if the sensors are usable at 3.3V?
The datasheets for the main ICs are available on the Andymark page. You can look at those for the supported input voltage range.
This is from the TI datasheet for the hall effect latch sensor:
The DRV5013 device is designed to operate from an input voltage supply (VM) range between 2.5 V and 38 V. (page 19)
So yes, it can run on 3.3V. Of course I only checked the one sensor but I imagine they all work the same in terms of power load.
