Andymark Swerve Drive Specialties - Incorrect Falcon Pinion Gear
We recently ordered 4 MK4Is from AndyMark (L1, falcon pinions, colson wheels). All 4 arrived yesterday with incorrect falcon pinions. Each kit has 1 20dp 14T falcon pinion gear, and one much smaller 15T falcon pinion gear. Everything we have seen shows we should have received 2 of the 14T Pinion Gears. Has anyone else had this issue? Who should we contact, SDS or AndyMark?
Thanks.
Hi Grant,
It sound like you were shipped the MK4 pinion gear set instead of the MK4i set by mistake. Please send your order number and your above message to [email protected] and we will get you the correct pinion set sent out ASAP.
