Announcement - Manly Innovations QAS Pre-Production Units In
Our first pre-production units are in and look great! We initially planned on producing a higher quantity in our first production, however, to mitigate risk in our current economic environment, we have decided to start with a lower initial production quantity which will arrive in the first week of January. In doing so, we have incurred a cost increase, which is reflected in our slight price increases.
We are pricing the QAS Quad set at $279 for the FRC purchasing season, which with a base profit margin would be at $310. This will not include the 4 extra tang plates as it would increase the cost even more. After discussions with some teams, we have found that many who would use this for bumper attachments, use reversible bumper covers and the extra tang plates would not be a necessity.
The QAS is a game changing solution for modularization of any system, where you need a robust connection for mounting, while desiring the capability of connecting and disconnecting as needed without using hardware, while having a secondary locking capability. The QAS is also sold in a Duo set. Additional tang plates are available to expand modularization capabilities in various areas of your robot design, as well as carts and transport systems.
Let me know if you have any questions.
Joe
Just a note - this cost increase does not impact those teams who have already made a pre-purchase at the original listed price.
This QAS mounting system has quite the interesting patent…
Yes - back in 2013, as a veteran, I came up with an idea for military CQC applications, but realized later that the attachment portion of the system had a much broader capability than what I had designed it for. While the first product had market hurdles, I rewrote the patent for a much broader utility application, but dude to the original filing, I had to retain much of the original information and covered all of the current claims in the final patent application. Now with the newly filed transfer of energy patent, the possibilities of applications are almost limitless.
Neat, where do you press to disengage and detach the mechanism or in this case, bumper?
https://www.manlyinnovations.com/qas/
In the image I have highlighted the button. When you engage the tang plate it is locked in place and the release button protrudes from the face by about 6mm.
I may be missing it but what is the weight?
Also, what are the tang and slide plates made of?
It’s important to note that once these are mounted, there are absolutely no tools required to connect and disconnect the QAS. Just push the assembly together to engage and push the button(s) to disengage.
The body was is 2.8oz per QAS and the tang plate is .4oz. So for a set of four on a robot you are looking at 12.4oz in total weight. If you are using them for bumpers and you have the bodies on the robot frame you are looking at 11.2oz.
Others are planning to use a couple for a bottom maintenance access plate/shield. Others are planning to use them for modularity in their transport carts. It would be exciting to see some teams follow through on discussions of looking at modularity in game functionality with sub-systems.
Love the product, I think it simplifies many of the custom solutions teams have attempted to make for quick attach/detach bumpers. Would it be possible for teams to access the 3D block CAD model without making purchases? I know several teams have strict purchasing rules, and many (including my own) may have trouble being able to purchase a set without first having a local cad file to show how it could interface with our robot for the administrators who approve purchases. By making the block CAD (somewhat) public, maybe even just for teams that request it for this specific purpose, it could allow for more teams with stricter purchasing rules to acquire a set. If this could be done, I know many of us would appreciate it immensely. Thanks!
Absolutely. I will make a fresh post so all teams will see it front and center without having to search for it.
Thank you so much, I know that will be helpful for my team especially, as well as many others out there who are interested in the QAS Set.
Is there a category in the forum that would best suit getting this out to the teams? I was thinking Technical>>CAD, but it would be good to confirm.
I agree, I also think that Technical>>CAD would be the best for that post.
Ok - it will be up in just a couple of minutes.
Perfect, thanks again!
Is manly a family name? Or is it about these latches being strong?
Was thinking about that earlier; I checked his CD profile and saw his name was Joe Manly.
So I’m assuming “Manly” is a family name. Or maybe he is just very excited about his latches being strong and got his legal last name changed because of it. I prefer the second option.
:joy: I’ve had variations of that question my whole life. It is definitely my name, but I definitely think there is a fit with the strength of the QAS.
What would make this better than using a couple of bolts and inserts for instance? Many, many teams use that as a solution, and it works great. No shade towards your product, but it seems overengineered for a task that doesn’t need that bulk.
