Introducing Scoutradioz Voyager
Get excited!
Get ready to revolutionize your scouting experience with the introduction of Voyager! With Voyager, you’ll harness the full power of Scoutradioz at any competition, regardless of internet connectivity. Whether you’re at a bustling event with robust WiFi or in the depths of a competition venue with limited data or no reception, Voyager ensures you never miss a beat. Embrace the freedom to scout anytime, anywhere, and elevate your team’s performance to new heights with Voyager by your side.
Voyager is the name of Scoutradioz’ new installable Progressive Web App (PWA), designed from the ground up for offline use at competitions with limited or no WiFi or cellular reception using QR codes to transmit between devices.
Behind the name Voyager
The name Voyager was chosen because like the Voyager 1 and 2 space probes, your device will spend most of its time without connection to “home base” (the central Scoutradioz server) and periodically send necessary data back and forth when possible.
Team 102 used Voyager to great success at an offseason competition in November and now we’re ready to share it with the whole FRC community!
(Note: Voyager is an add-on to Scoutradioz rather than a replacement; in order to use Voyager your team needs to be set up in Scoutradioz)
Sign up for Scoutradioz here!
No internet, No problem!
Forget about the hassle of needing an internet connection! With Voyager, all the essential data is stored directly on your device, allowing you to seamlessly scout at competitions, even in areas with limited or no WiFi or cellular reception. Instead of relying on constant connectivity to a central server, Voyager utilizes innovative QR code technology to transmit assignments or completed forms between devices.
Plus, when the Scouting Lead finds a spot with connectivity, data can be easily synced up to the main app, ensuring you’re always up to date. Say goodbye to connectivity worries with Voyager, your reliable scouting companion, even in the most challenging environments!
Learn more about Voyager Here!
How to install Voyager to your devices
“Voyager” isn’t an app in an app store; all you need to do is go to the webpage & the ‘app’ gets cached on your device. Teams onboarded into Scoutradioz can try out Voyager at Voyager Website
If you haven’t heard about Scoutradioz™ before
- Scouting-as-a-Service: Utilize students’ mobile devices without the need for additional hardware or installations.
- Built-in charts and analytics: Quickly visualize comparative per-robot data and export it to CSV.
- Event management tools: Audit match assignments, manage scouters, and handle member lists effortlessly.
- Live match results and ranking updates: Get automatic updates via The Blue Alliance API.
- Responsive web app: Optimized for mobile devices with tablet and desktop browser compatibility.
- Match Predictions: Achieve a success rate of 80%-85% with match outcome predictions.
- Scouting Accuracy: Measure individual scouter accuracy and identify areas for improvement.
Learn More about Scoutradioz™ Here!
Join the Discussion!
Got feedback or questions about Voyager? Join us on Discord to share your thoughts, suggestions, or experiences! Your input helps us improve Voyager and tailor it to better suit your scouting needs.
