WPILib has the new april tag map, or i need to download the new map, if i need, how can i import the new layout to use with my LL?
The limelight downloads page has the 2025 field layout here:
i put this in deploy? or other folder?
When connected to the limelight, make sure to switch your pipeline type to apriltags in the input tab. Switch over to the advanced tab, and turn on full 3d targeting. In there, you should see a button to allow you to upload the map file I linked earlier. The field will still show the graphics from the previous year, but the april tags will be in the correct location:
It is not that important but at what point will the graphics be updated? In the next version release?
My assumption would be the 15th:
