I think Mr. Derek Bessette plays a part in this as well, if I’m not mistaken.
And possibly earning themselves a yellow card.
2106 would use its chain driven manipulator to surround an opponent ball and grip it just enough that it is still herded, not possessed, and therefore not incurring any penalties. Then they must stay in the corner holding the ball the whole match.
You might rethink that:
Meanwhile, 20 would be lapping like crazy with their bot while playing keep-away with the trackball, to try and overcome the penalty points. I can see them getting 7-9 laps in tele, so that’s 14-18 points.
Racking up 2 points for the opponents each time they cross their ball.
Lastly, 330 would need to use its ability to herd while possessing to control both of its trackballs …
Also illegal - see <G27>.
You are correct, sir, I am a bit rusty on the rules, so thanks for pointing out where there were holes. You are right on pretty much every point, so I think my strategy definitely needed some rethinking. :o
I guess that team 20’s strategy would need to change as well. Perhaps having them hurdle alongside 330, racking up the score. Or swap 20 with 968, as their hybrids are close in score, and 968 can hurdle more in tele.
I’m not sure, however, if 2106 would be considered in possession of the ball. The ball would not be “supported,” because it would be resting on the ground, and not being held. I suppose it might be grounds for capturing, but if 2106 loosened their manipulator by about a foot there would be some room for it to move, at the expense of your total defense.
Thanks again for helping me remember to check the manual before strategizing!
Which is exactly why I have 25 as the third bot, they can knock both balls off, at least in the match we were paired with them. And I know 968 can get lots of lines, I just meant that they just couldn’t knock off both balls.
I don’t recall the exact wording of the rule, but it says something to the effect of that if you’re pushing the ball around, stop, change directions, and the ball comes with you, you’re in possession of it, which would be what would happen in this scenario.
330 on Galileo used their gripper arms to pin a trackball into the all and no penalties were called. 2106 used a similar method, so as long as they dont pick up the ball, it would not incur penalties.
Yeah, but 330 doesn’t encircle the ball. They just go halfway around.
The ball pinning strategy that you guys are discussing cost us in the Philly semi finals and on Archi. Every time I challenged the rulings I was always told that it’s not illegal if the ball does not move as the robot does. Basically if the robot moves and the ball then goes into unrestrained motion it’s legal. Now if the robot moves and the ball moves in restrained motion with the robot it’s considered illegal
It also wasn’t effective against 1114, because they were able to roll it out. They are THAT good. I think 2106 would have the same problem.
See about 40 seconds into this video: http://www.thebluealliance.net/tbatv/match.php?matchid=10451
1114 is the best scorer. They aren’t untouchable, and in any given match, can get outscored by certain robots given the circumstances, but they are, in my opinion, the single best bot this year in the competition. Going into the championships, I thought it would be their title to lose, and I know anything can happen, but they didn’t lose it. I don’t mean to belittle 217 or 148. They are great robots, but 1114 won every single competition they entered. 217, 148, and others were great robots but not as dominant.
This nudged a thought that has been brewing over the past couple of days. It could probably brew for a couple more but I’ll give it a shot.
When the posts began in the CD fora after the 2008 Championship and when photos began to appear, we were lucky to have some of our World Champions contributing their thoughts, reactions, and feelings in the threads. The teams, the coaches, and the drive teams were all so happy. What seemed to come from all the happiness and celebration and found its way into words was the respect that all of them had for each other and how they made up for weaknesses that occurred/popped up in the matches, depending on the alliance to overcome those weaknesses and challenges by working together and communicating with each other - all the while competing for the victories on Galileo and then on Einstein. The respect, in my mind, has been developed over time and is a great nod towards the importance of having engineers involved in the FRC program as mentors and as coaches, working side by side with students. The winning alliance showcased this importance and it also reflected a respect and appreciation that teams can have for themselves and for each other. Whether one robot was more dominant or not in the end or whether this worthy alliance that competed on Einstein and brought home the gold - can be beaten, is not important to me. They have already proven that they can win and they can win even when things get a little tough or challenging. That is when the alliance works together showing the strength of character and the level of respect - when it gets a little tough. And, that is what the robotics competition part of FIRST is about. I said all that and did not use the term, Gracious Professionalism, but it was present there between the lines and within those teams. Still is.
Very good point.
My team was not good enough to even make the eliminations at Championships, … this year. We made championships our first two years, and are extremely proud coming from a smaller school and with only 13 members. We learned a great deal about engineering, teamwork, and many other things including the possibly overused, but underappreciated term, gracious professionalism. 1114, 148, and 217 came together to build robots that were amazing, but they also worked together and became more than just the sum of their parts. They decided on a strategy that was effective and worked extremely well, and executed it brilliantly.
I don’t know, I think this guy’s got a better hybrid mode.
Look how big he is compared to that trackball.
(try to fit him into the box, or the arena for that matter)
Well he isn’t that big in the movie
I don’t have his exact dimensions, but I’d be willing to bet he could even fit inside a trackball, let alone the box
walllleeee…
An alliance to beat them: 968/67/27. 968 and 67 for scoring and 27 as a backup scoring/lapbot. Yes 27 is a dangerous scoring machine in their own right but they are really fast if they can get their transmission troubles worked out. 968 had one of the best scoring systems out there and 67 was a very scary machine as well.
I decided to go with 3 dangerous scoring robots as opposed to defense. My logic is, 27 can run defense against 217, or 1114 but if either of the other two teams break their scoring mechanism they can trade places. This allows a level of redundancy that I do not see in 1114/217/148.
I sure hope I get to see team 27 run defense against team 1114 or 217 for that matter whether during qualifying or elimination at IRI.
And for the beginning of the thread, Team 1114’s coach was Derek Bessette as Jane pointed it out.
well, i am just starting up my team
i can’t give any comment
but i think, the strongest team will also be replace within a certain amount of time
people leave and new people come
so the question is, are you ready to beat them?
Students leave and new students come.
But mentors are forever.
well, not really
sometime some mentors do leave for their reasons
but yeah, I agree that mentors are always there and so do the students will also be interested in joining the FIRST community
just like how the open soruce community works
