Are Fans Pneumatic Devices?
If a team is really really bad does that make them a pneumatic device because they suck?
You must spread some Reputation around before giving it to notmattlythgoe again.
:frowning:
Serious question…
The fan is not a pneumatic device
but the tube being filled with air is
right?
No. The pressure would be too low and if the fan is turned off the pressure is lost.
Yes.
Source: we suck so much were not even making elims this weekend :frowning:
FRC422 The Mech Tech Pneumatic Devices
You think that would fit in the prematch screen?
This thread blows…
Obviously fans are pneumatic devices. The definition of pneumatic is of or relating to air, gases, or wind.
The definition of fans is any device for producing a current of air by the movement of a broad surface or a number of such surfaces.
I see a relation.
/sarcasm
Better than the tab character you put in your team name :wink:
Exactly. Yankees fans are Airheads.
It was the dragon emoji, I swear it worked on my end.
If we are using absolutes, this thread could be sucking too…
This thread reminds me of our defensive fan development for 2013…
I am still not doing a very good job…
And airheads are clearly pneumatic devices.
If the Yankees could steal the Mariners suck that would be great…
This is an engineering regulation, not specifically first. IIRC pneumatic systems don’t need certification if they operate below 15PSI. (I was googling around and can’t find a source, my value could also be wrong).
R6
Traction devices must not have surface features such as … hard plastic studs, cleats…
W tread versawheels are hard plastic, and have what could be described as studs and/or cleats. This was tangential to my point. It was an example of “illegal but not going to be called”.
I am thinking it must be a slow day in Chief Delphi land.
Fans were used in Lunacy to help push robots around.
As if the NYY opening day wasn’t already a disappointment… :frowning:
