Are these pressure gauges FRC legal?
We purchased these regulators from Andymark as a weight saving matter, but as you see the regulator gauges are quite small and are difficult to look at. Are these regulators FRC Legal since they’re difficult to look out.
Links to Regulators
Is there a rule that you are worried that it might violate?
just worried about inspection and how they are difficult to look at to find the pressure
They are legal. Similar gauges, regulators, and other pneumatic parts can be found at automation direct as well - and note that every team has a $50 Automation Direct voucher they can use! It’s on your primary and secondary team lead’s FIRST dashboard.
For the inspector’s sake and for your own sake, install them where they are easily visible. You will want to monitor the pressure to make sure your pneumatic system is working correctly.
