Are they really robots?
A robot is any object that passes inspection.
Ok, I see where you’re getting at. You’re right, I guess that would count, but that’s like a really specific ambition project for no electronics, like what I mentioned before:
I know what can be done with just mechanics, but I’d be pretty impressed if you were able to make a full fledged “robot” like a hobby robot out of just mechanical parts.
But what I was talking about was more general, like my other example:
…if you scrapped all electronics on your FRC robot, had a really long hand crank with a universal joint that gives power to the wheels, and a similar hand crank for directly altering the steering. That’s more of a very fancy mechanism.
PAR_WIG1350 said
if the mechanism is designed to react in response to stimuli (read as forces) in a way that could be considered interaction, that might be debateable.
I would take that to be a mechanism that has interaction (with forces), not something that interprets signals and “thinks” on some level.
He also said
Autonomy is more direct than remote control. why then does a MORE direct system disqualify the device as a robot?
That’s confusing to me. Autonomy is more direct in that there’s no “middleman,” but it’s more complex in that the robot really thinks and decides. When I say more direct, I mean less thinking/interpreting signals and just direct movement/action.
Hope that helps; does that portray my ideas?
This is where you’re getting tripped up I think. A program that makes a decision is executing a series of equations and performing an action based on the answer. There is no reason why a mechanism couldn’t be designed to perform the exact same calculation and take the exact same action based on the answer. The reason that it’s not done normally in real life is complexity, size, and efficiency.
Check out this very cool machine that uses several “binary mechanical computers.” These computers are programmed by placing pins in different locations, but they are computers none the less. Their final machine will use sensors to synchronize the clock with the rising sun through the use of shape-memory alloy wire and a very unique lens.
Might be off topic a bit, but consider the carburetor, vs electronic fuel injection. The carburetor is a relatively simple mechanical device that uses some pretty basic principles to meter fuel quite accurately under many different operating conditions. EFI uses a computer, several sensors, several actuators, a sort of complicated program, and calibrated lookup tables to do the same job.
I doubt either is really a robot, but the analog mechanical device is my favorite if I’m the one paying for and maintaining the thing.
Or consider a gas turbine engine fuel control. Up until about the early-70s, these were analog hydromechanical computers. They consisted of 3D sliding cams, spinning flyweights, EDM-contoured valves, servo valves, check valves, pistons, levers, pressurized metal bellows, helium-filled coils, etc etc.
Please navigate to:
http://www.robotics.utexas.edu/rrg/learn_more/history/
and you get:
According to the Robot Institute of America (1979) a robot is:
“A reprogrammable, multifunctional manipulator designed to move material, parts, tools, or specialized devices through various programmed motions for the performance of a variety of tasks”.
With this debate, we will see what the community thinks when the BSA Robotics Merit Badge is published April 2011.
I think a lot of people - laymen - think of a “Robot” simply as a mechanical man. A machine that mimics the shape and motion of a human.
From that perspective, many people would think our machines weren’t robots, but some other kind of machine.
Hmmm … that’s a vaguely familiar acronym … where have I heard that before? :rolleyes:
I think they are robots.
Every time the operate moves the joystick, presses a button, or something else he is sending a signal (which acts the external stimuli) to the robot telling it to execute a piece of preprogrammed code in response.
In even more abstract sense you could think of the driver station as a big sensor array. The driver is creating the external stimuli that in turn makes the robot execute a preprogrammed response.
Then what makes that different from a gaming console? It does preprogrammed response on the screen, responds to external stimuli…
Gaming consoles are not machines; they’re not largely mechanical. At most, they have vibration functions. Robots have mechanical emphasis.
Are they Robots?
I think the various messages in this thread have unequivocally established that the answer to this question is: “Of course they aren’t robots; they are obviously and unambiguously robots.”
Any machine that is computerized is a robot.
-Isaac Asimov
I think that should about sum it up.
So according to Asimov, cars and airplanes are robots.
I don’t think it sums it up quite as neatly as you thought.
Parts of some of them are, certainly. Cruise control, the fuel metering system on just about any modern car, paddle-shifting transmissions, the entire hybrid powertrain on a Prius, etc. An airplane under the control of an autopilot is an autonomous robot using just about any definition that doesn’t require robots to have hands.
Autonomy seems to come up often in this discussion. This brings me to three questions:
Is there a distinction, as far as autonomy and the classification thereof is concerned, between closed-loop and open-loop programming?
Are the controls (joysticks) considered to be sensors, or simply inputs?
Is there a distinction between sensors and inputs?
I don’t think such a distinction would be important when deciding whether or not a machine counts as a robot. There are many examples of open-loop robotic “pick and place” machines in assembly lines, for example. But there’s definitely room for debate on the topic, and one could make a valid comparison between totally open-loop systems and clockwork wind-up mechanisms.
I would consider that a matter of semantics rather than of essence. The system analysis could be done with either choice of label.
I probably wouldn’t use the word “sensor” to describe an input device such as a keypad. Sensors typically measure or detect a quality of the environment, while inputs can be pure information without a definite physical analog.
I’d classify inputs as being more general and sensors as a specific type of input, though I’ll decline to define it here. One might also distinguish inputs which require human interaction as “manual inputs”.
But just to add to the confusion, within each manual input probably lies some kind of sensor and/or transducer - within keypads there are gizmos which close circuits when enough force is exerted (switches) and within joysticks there are thingamabobs which sense position and output voltage (potentiometers).
  • Steve
When an operator is operating a robot is the operator using the robot or is the robot using the operator?
Are we not just part of the robotic system… our eyes, brains and hands doing the same functions as other sensors that the robotic system uses to perform a particular function…
BE the robot…!! Resistance is futile…
Is the task what makes the robot? In fulfilling the task we are just helping the robot make the decisions it must to function…
Our input comes from our very own sensors… which are programmed in our brain… we use those sensors to send stimuli to the robot which allows it to take those signals and translate them into movement… and task fulfillment…
Robot philosophy
What happens if a robot controls its own joystick. Is it really a robot?
