Armabots turret
Hello im Gal, recently i saw a turret nade by Armabots. Im very intrested about the bearing, where can i find it? (or something simuler).
thank
-Gal-
GreyT is also selling a COTS turret this year via WCP
https://www.wcproducts.com/greytturret
I don’t have any firsthand experience with either product.
If you’re looking for a turret bearing, there are some inexpensive ones on amazon: https://www.amazon.com/Diameter-Aluminum-Hardware-Turntable-Dining-table/dp/B01MQSBP7B/ref=mp_s_a_1_3?keywords=turntable+bearing+10&qid=1579618468&sr=8-3
I think the bearing is custom, you could try contacting Armabot and see if you can work out details about the bearing. If not there is always amazon.
I highly recommend the armabot turret, but if you just want the bearing, it’s the 16’’ heavy duty one from Amazon. https://www.amazon.com/dp/B06ZYWSKQW/ref=nav_timeline_asin?_encoding=UTF8&th=1&psc=1
We got ours from the source with extra holes and higher tolerance on the hole location. A word of caution, if you are going to drill custom holes, be sure to tape over the bearing so you don’t get chips inside.
