I am in despreate need of help. My team has decided that we should try command base instead of time robot this year. I have been succesful in making subsystems and commands by following and using https://github.com/Delmar-Robotics-Engineers-At-MADE/2024-Robot/blob/main/src/main/java/frc/robot/RobotContainer.java as a guide to help me make my subsystems and commands. The last step is to assign buttons to our xbox controller so we can drive. But i am completely lost, no matter how many things i change i still end up with errors. We are using two xbox controllers, one just for the driver and the second one is just for the operator to score and climb in the game. Unfortunatley i am unable to publish my code to github because of difficulties but i can copy it here:
// Copyright (c) FIRST and other WPILib contributors.
// Open Source Software; you can modify and/or share it under the terms of
// the WPILib BSD license file in the root directory of this project.
package frc.robot;
import edu.wpi.first.math.MathUtil;
import edu.wpi.first.wpilibj.XboxController;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import frc.robot.Commands.Drivetrain.RapidHeading;
import frc.robot.Constants.ArmConstants;
import frc.robot.Constants.ClimberConstants;
import frc.robot.Constants.DriverConstants;
import frc.robot.Constants.IntakeConstants;
import frc.robot.Constants.OIConstants;
import frc.robot.Constants.OperatorConstants;
import frc.robot.Constants.ShooterConstants;
import frc.robot.subsystems.Arm;
import frc.robot.subsystems.Climber;
import frc.robot.subsystems.DriveSubsystem;
import frc.robot.subsystems.Intake;
import frc.robot.subsystems.Shooter;
import edu.wpi.first.wpilibj2.command.Command;
import edu.wpi.first.wpilibj2.command.InstantCommand;
import edu.wpi.first.wpilibj2.command.ParallelCommandGroup;
import edu.wpi.first.wpilibj2.command.RunCommand;
import edu.wpi.first.wpilibj2.command.SequentialCommandGroup;
import edu.wpi.first.wpilibj2.command.button.CommandJoystick;
import edu.wpi.first.wpilibj2.command.button.CommandXboxController;
import edu.wpi.first.wpilibj2.command.button.JoystickButton;
import com.pathplanner.lib.auto.NamedCommands;
import com.pathplanner.lib.commands.PathPlannerAuto;
import frc.robot.commands.BlindFire;
import frc.robot.commands.Warning;
import frc.robot.commands.HoldArm;
import frc.robot.commands.RunArmClosedLoop;
import frc.robot.commands.HoldClimber;
import frc.robot.commands.HomeClimber;
import frc.robot.commands.RunClimberManual;
import frc.robot.commands.Feed;
import frc.robot.commands.HoldIntake;
import frc.robot.commands.IntakeNoteAutomatic;
import frc.robot.commands.RunIntakeOpenLoop;
import frc.robot.commands.AccelerateShooter;
import frc.robot.commands.RunShooterAtVelocity;
import frc.robot.commands.ShootNote;
- This class is where the bulk of the robot should be declared. Since Command-based is a
- “declarative” paradigm, very little robot logic should actually be handled in the {@link Robot}
- periodic methods (other than the scheduler calls). Instead, the structure of the robot
- (including subsystems, commands, and button mappings) should be declared here.
public class RobotContainer {
// The robot’s subsystems
private final DriveSubsystem m_robotDrive = new DriveSubsystem();
private final Arm m_arm = new Arm(ArmConstants.kLeftID, ArmConstants.kRightID);
private final Intake m_intake = new Intake(IntakeConstants.kIntakeID, IntakeConstants.kSensorDIOPort);
private final Shooter m_shooter = new Shooter(ShooterConstants.kTopID, ShooterConstants.kBottomID);
private final Climber m_portClimber = new Climber(ClimberConstants.kPortID, ClimberConstants.kPortDIO);
private final Climber m_starboardClimber = new Climber(ClimberConstants.kStarboardID, ClimberConstants.kStarboardDIO);
// The driver’s controller
CommandXboxController operatorXboxController = new CommandXboxController(OIConstants.kOperatorControllerPort);
CommandJoystick driverXboxController = new CommandJoystick(OIConstants.kDriverControllerPort);
private final Dashboard dashboard;
// Command Groups
ParallelCommandGroup feedAndShootSubwoofer = new ParallelCommandGroup(
new ShootNote(m_shooter, ShooterConstants.kSubwooferSpeed),
new Feed(m_intake)
ParallelCommandGroup feedAndShootPodium = new ParallelCommandGroup(
new ShootNote(m_shooter, ShooterConstants.k3mSpeed),
new Feed(m_intake)
SequentialCommandGroup shootSubwoofer = new SequentialCommandGroup(
new RunArmClosedLoop(m_arm, ArmConstants.kSubwooferPos),
new AccelerateShooter(m_shooter, ShooterConstants.kSubwooferSpeed),
SequentialCommandGroup shootPodium = new SequentialCommandGroup(
new RunArmClosedLoop(m_arm, ArmConstants.k3mPos),
new AccelerateShooter(m_shooter, ShooterConstants.k3mSpeed),
feedAndShootPodium
ParallelCommandGroup intake = new ParallelCommandGroup(
new IntakeNoteAutomatic(m_intake),
new RunArmClosedLoop(m_arm, ArmConstants.kIntakePos)
ParallelCommandGroup homeClimbers = new ParallelCommandGroup(
new HomeClimber(m_portClimber),
new HomeClimber(m_starboardClimber)
ParallelCommandGroup forceFeed = new ParallelCommandGroup(
new RunIntakeOpenLoop(m_intake, IntakeConstants.kReverseSpeed),
new RunShooterAtVelocity(m_shooter, ShooterConstants.kAmpSpeed)
ParallelCommandGroup forceReverse = new ParallelCommandGroup(
new RunIntakeOpenLoop(m_intake, -IntakeConstants.kReverseSpeed),
new RunShooterAtVelocity(m_shooter, -ShooterConstants.kAmpSpeed)
SequentialCommandGroup amp = new SequentialCommandGroup(
new RunArmClosedLoop(m_arm, ArmConstants.kBackAmpPos),
forceFeed
private final SendableChooser autoChooser;
// temp strings
private String k1NC = “1-Note Center”;
private String k1NAS = “1-NoteAmpSide”;
private String k2NAS = “2-NoteAmpSide”;
private String k2NFC = “2-NoteFieldCenter”;
private String k2NMS = “2-NoteMidSpeaker”;
private String k2NMSA = “2-NoteMidSpeakerAmp”;
private String k3NAS = “3-NoteAmpSide”;
private String k3NMSC = “3-NoteMidSpeakerCenter”;
private String kBL = “BasicLeave”;
private String kBS = “BasicShoot”;
private String kEntropy = “Entropy”;
- The container for the robot. Contains subsystems, OI devices, and commands.
public RobotContainer() {
// Configure the button bindings
driverXboxController.setXChannel(1);
driverXboxController.setYChannel(0);
driverXboxController.setTwistChannel(2);
configureButtonBindings();
// Register Named Commands
NamedCommands.registerCommand("intake", intake);
NamedCommands.registerCommand("shootSubwoofer", shootSubwoofer);
NamedCommands.registerCommand("shootpodium", shootPodium);
NamedCommands.registerCommand("armInside", new RunArmClosedLoop(m_arm, ArmConstants.kStowPos));
NamedCommands.registerCommand("homePort", new HomeClimber(m_portClimber));
NamedCommands.registerCommand("homeStarboard", new HomeClimber(m_starboardClimber));
NamedCommands.registerCommand("armDown", new RunArmClosedLoop(m_arm, ArmConstants.kIntakePos));
// Build an auto chooser. This will use Commands.none() as the default option.
autoChooser = new SendableChooser<>();
autoChooser.addOption("1-Note Center", new PathPlannerAuto(k1NC));
autoChooser.addOption("1-NoteAmpSide", new PathPlannerAuto(k1NAS));
autoChooser.addOption("2-NoteAmpSide", new PathPlannerAuto(k2NAS));
autoChooser.addOption("2-NoteFieldCenter", new PathPlannerAuto(k2NFC));
autoChooser.addOption("2-NoteMidSpeaker", new PathPlannerAuto(k2NMS));
autoChooser.addOption("2-MidSpeakerAmp", new PathPlannerAuto(k2NMSA));
autoChooser.addOption("3-NoteAmpSide", new PathPlannerAuto(k3NAS));
autoChooser.addOption("3-NoteMidSpeakerCenter", new PathPlannerAuto(k3NMSC));
autoChooser.addOption("BasicLeave", new PathPlannerAuto(kBL));
autoChooser.addOption("BasicShoot", new PathPlannerAuto(kBS));
autoChooser.addOption("Entropy", new PathPlannerAuto(kEntropy));
// Another option that allows you to specify the default auto by its name
// autoChooser = AutoBuilder.buildAutoChooser("My Default Auto");
dashboard = new Dashboard(m_robotDrive, m_arm, m_intake, m_shooter, m_portClimber, m_starboardClimber, autoChooser);
// Configure default commands
m_robotDrive.setDefaultCommand(
new RunCommand(
() -> m_robotDrive.drive(
-MathUtil.applyDeadband(driverXboxController.getX()*DriverConstants.kDefaultSpeed, OIConstants.kDriveDeadband),
-MathUtil.applyDeadband(driverXboxController.getY()*DriverConstants.kDefaultSpeed, OIConstants.kDriveDeadband),
-MathUtil.applyDeadband(driverXboxController.getTwist()*DriverConstants.kDefaultSpeed, OIConstants.kDriveDeadband),
true, true), m_robotDrive));
// The left stick controls translation of the robot.
// Turning is controlled by the X axis of the right stick.
operatorXboxController.leftStick().or(operatorXboxController.rightStick()).toggleOnTrue(
new RunCommand(
-MathUtil.applyDeadband(operatorXboxController.getLeftY()*OperatorConstants.kManoeuvreSpeed, OIConstants.kDriveDeadband),
-MathUtil.applyDeadband(operatorXboxController.getLeftX()*OperatorConstants.kManoeuvreSpeed, OIConstants.kDriveDeadband),
-MathUtil.applyDeadband(operatorXboxController.getRightX()*OperatorConstants.kManoeuvreSpeed, OIConstants.kDriveDeadband),
driverXboxController.povCenter().whileFalse(
new RapidHeading(
driverXboxController.getHID().getPOV(),
-MathUtil.applyDeadband(driverXboxController.getY(), OIConstants.kDriveDeadband),
-MathUtil.applyDeadband(driverXboxController.getX(), OIConstants.kDriveDeadband),
m_robotDrive));
driverXboxController.button(DriverConstants.kTurbo).whileTrue(
new RunCommand(
-MathUtil.applyDeadband(driverXboxController.getTwist(), OIConstants.kDriveDeadband),
operatorXboxController.start().whileTrue(
new RunCommand(
-MathUtil.applyDeadband(operatorXboxController.getLeftY(), OIConstants.kDriveDeadband),
-MathUtil.applyDeadband(operatorXboxController.getLeftX(), OIConstants.kDriveDeadband),
-MathUtil.applyDeadband(operatorXboxController.getRightX(), OIConstants.kDriveDeadband),
false, true), m_robotDrive));
// Subsystem Default Commands
m_intake.setDefaultCommand(new HoldIntake(m_intake));
m_arm.setDefaultCommand(new HoldArm(m_arm));
m_shooter.setDefaultCommand(new RunShooterAtVelocity(m_shooter, ShooterConstants.kIdleSpeed));
m_portClimber.setDefaultCommand(new HoldClimber(m_portClimber));
m_starboardClimber.setDefaultCommand(new HoldClimber(m_starboardClimber));
- Use this method to define your button->command mappings. Buttons can be
- created by
- instantiating a {@link edu.wpi.first.wpilibj.GenericHID} or one of its
- subclasses ({@link
- edu.wpi.first.wpilibj.Joystick} or {@link XboxController}), and then calling
- passing it to a
- {@link JoystickButton}.
private void configureButtonBindings() {
driverXboxController.button(DriverConstants.kSetX)
.whileTrue(new RunCommand(
() → m_robotDrive.setX(),
m_robotDrive));
driverXboxController.button(DriverConstants.kIntake).whileTrue(intake);
driverXboxController.button(DriverConstants.kHoldArmDown).toggleOnTrue(new RunArmClosedLoop(m_arm, ArmConstants.kIntakePos));
driverXboxController.button(DriverConstants.kAutoIntake).and(driverXboxController.button(DriverConstants.kIntake)).onTrue(
new InstantCommand(() -> m_robotDrive.zeroHeading(), m_robotDrive)
driverXboxController.button(DriverConstants.kIntake).and(driverXboxController.button(DriverConstants.kAutoIntake)).onTrue(
driverXboxController.button(DriverConstants.kSelfDestruct).onTrue(
new InstantCommand(() -> System.out.println("¡KABOOM!"))
operatorXboxController.start().whileTrue(new Warning("¡OVERRIDE!"));
operatorXboxController.start().and(operatorXboxController.povUp()).whileTrue(new RunArmClosedLoop(m_arm, ArmConstants.kManualSpeed));
operatorXboxController.start().and(operatorXboxController.povDown()).whileTrue(new RunArmClosedLoop(m_arm, -ArmConstants.kManualSpeed));
operatorXboxController.start().and(operatorXboxController.povRight()).whileTrue(forceFeed);
operatorXboxController.start().and(operatorXboxController.povLeft()).whileTrue(forceReverse);
operatorXboxController.back().whileTrue(homeClimbers);
operatorXboxController.rightBumper().whileTrue(new RunClimberManual(m_starboardClimber, ClimberConstants.kManualSpeed));
operatorXboxController.rightTrigger().whileTrue(new RunClimberManual(m_portClimber, -ClimberConstants.kManualSpeed));
operatorXboxController.leftBumper().whileTrue(new RunClimberManual(m_portClimber, ClimberConstants.kManualSpeed));
operatorXboxController.leftTrigger().whileTrue(new RunClimberManual(m_portClimber, ClimberConstants.kManualSpeed));
operatorXboxController.a().whileTrue(new RunArmClosedLoop(m_arm, ArmConstants.kBackAmpPos));
operatorXboxController.b().whileTrue(shootSubwoofer);
operatorXboxController.y().whileTrue(new RunArmClosedLoop(m_arm, ArmConstants.kSubwooferPos));
operatorXboxController.x().whileTrue(new IntakeNoteAutomatic(m_intake));
operatorXboxController.x().whileTrue( new RunShooterAtVelocity(m_shooter, ShooterConstants.kSubwooferSpeed));
- Use this to pass the autonomous command to the main {@link Robot} class.
- @return the command to run in autonomous
public Command getAutonomousCommand() {
return autoChooser.getSelected();
Please help!!! Thank you in advanced!!!
