And is the limit due to the the RoboRio or the Talon?
My understanding is the current rate limit is the roboRIO’s ability to send CAN messages via frc netcom.
@ozrien might be able to shed some more light on the specifics.
The baud rate of the CAN bus is 1 megabit.
For information on how long it takes for CAN API calls, see our blog post on CAN performance here:
https://phoenix-documentation.readthedocs.io/en/latest/blog/blog-perf.html
Most (but not all) of these are buffered in WPI C++/Java so they actually get called once every ~20 ms, regardless of how often you call getters.
Does this mean I can’t read CAN sensor (e.g. encoder) data any faster than 50Hz?
You can change how often the talon reports status information using the setPeriodicStatus
methods.
Oh, I read “buffered” as “cached.” That makes much more sense.
