Attach a google coral usb accelerator limelight error
Hello, we’re currently experiencing an issue where when we select the detector option on the pipeline type we get “attach a coral usb accelerator to use learning based features”. The lights on the coral do turn on so we know the cable works. We’ve also tried many cables to no avail. Any help is appreciated.
My programmers ran into that issue last year.
Their response -“ I had the same issue, i don’t fully remember exactly what I did. But I recommend re-etching the Limelight 2/3 using balenaEtcher and make sure you can connect to it via static ip. Should be 10.TE.AM.2, with team number in TE.AM.”
I think/hope you mean 10.TE.AM.11 or after as it is very important to not choose 2 as that is the RIO
You’re right. I believe my kids renamed the rio last year for a different IP not sure why.
If you haven’t solved this yet, I had a similar sounding issue when we first tried using the Coral and I ran through the basic setup of the Coral to see if I could check that it was working which resulted in the Coral being ‘reset’ (if you will) and useable. https://www.youtube.com/watch?v=sHwxd1B-hqo
