Attaching Plywood for base
What is the best way of attaching plywood for a base on our robot? Something like mounting brackets to our 2x1 extrusion or what?
What does your robot frame look like?
just 30 by 30, with the 2x1 aluminum extrusion from thrifty bot BACKORDERED: Thrifty 2" x 1" Grid Pattern Aluminum Extrusion and their swerve modules
As there are no bumps on the field this year, I would recommend drilling a few holes matching the bottom of the 2x1 in the plywood and then bolting through the 2x1 with the bolt head on the bottom of the robot. Also use a large washer between the bolt head and the plywood to spread the force of the bolt.
