I was wondering if you could wire the provided Automation Direct push button to the driver station digital I/O and if you can how would I go about wiring it?
Any SPST switch will work on a Driver Station Digital Input. Connect the switch between Ground and Signal. Also connect a 10k resistor between Signal and +5V. You’ll read 1 when the switch is open, and 0 when the switch is closed.
Thank you
That should help me alot
