Automous code
can sume one give to our team a Automous code pls
i asking from all teams pls help to our team
I am going to strongly suggest that you watch Tip Jar Video # 8.
Actually, I suggest that you start with number 5 and watch them in sequence.
Regards,
Mike
what we tride to do dont work thas way we ask :mad:
See this thread:
http://www.chiefdelphi.com/forums/showthread.php?t=75273&highlight=autonomous
It has both Labview and C++ code for general use.
Please post what you tried and someone will look at it and comment.
This is a problem NI is having with alot of teams [at least where I was at FRL]
the problem I dont think is your code but rather, that you need to Build your code first after every change. However if I misunderstood your problem or if I’m incorrect, then simply write a random drive will work. Tell your robot to move forward with a SetTime vi and a while loop and report your results here.
