We are using a limelight to guide the robot during both autonomous and some parts of teleop. We are using a Limelight.
The main issue is with seeking and ranging. We want one part of autonomous to help guide the robot in the correct distance between the target. And then another one positions the robot in the right angle.
Our code:
DriveSubsystem:
// All the imports:
package frc.robot.subsystems;
import static frc.robot.OI.*;
import static frc.robot.RobotMap.*;
import com.ctre.phoenix.motorcontrol.Faults;
import com.ctre.phoenix.motorcontrol.InvertType;
import com.ctre.phoenix.motorcontrol.can.WPI_TalonSRX;
import edu.wpi.first.wpilibj.ADXRS450_Gyro;
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
import edu.wpi.first.wpilibj.Timer;
import frc.robot.Robot;
import frc.robot.commands.DriveCommand;
import edu.wpi.first.wpilibj.command.Subsystem;
import edu.wpi.first.wpilibj.smartdashboard.*;
import edu.wpi.first.wpilibj.shuffleboard.*;
import edu.wpi.first.wpilibj.Sendable;
// Class declaration:
public class DriveSubsystem extends Subsystem {
// Creating variables/objects:
WPI_TalonSRX _rFront;
WPI_TalonSRX _rBack;
WPI_TalonSRX _lFront;
WPI_TalonSRX _lBack;
DifferentialDrive _diffDrive;
Faults _lFaults;
Faults _rFaults;
ADXRS450_Gyro gyro = new ADXRS450_Gyro();
// This instantiates, or sets up all of the variables. For example, it sets the right front wheel to the 2nd talon.
public DriveSubsystem() {
_rFront = new WPI_TalonSRX(1);
_rBack = new WPI_TalonSRX(2);
_lFront = new WPI_TalonSRX(3);
_lBack = new WPI_TalonSRX(4);
_diffDrive = new DifferentialDrive(_lFront, _rFront);
_lFaults = new Faults();
_rFaults = new Faults();
SmartDashboard.putData(_diffDrive);
SmartDashboard.putData(gyro);
// This is the driver method, that is run constantly in the DriveCommand. This is what takes raw data from the joysticks and pushes power to the motors.
public void Driver() {
SmartDashboard.putNumber("Joystick X value",leftJoystick.getX());
SmartDashboard.putNumber("Joystick Y value",leftJoystick.getY());
String work = "";
// Constantly update the forw and turn variables with joystick data:
double forw = -1 *leftJoystick.getRawAxis(1); /* pos = forward */
double turn = +1 *leftJoystick.getRawAxis(2); /* pos = right */
boolean btn1 =leftJoystick.getRawButton(1); /* if button is down, print joystick values */
// Margin of error for joystick sensitivity = 10%
if (Math.abs(forw) < 0.10) {
forw = 0;
if (Math.abs(turn) < 0.10) {
turn = 0;
// DRIVE THE ROBOT:
_diffDrive.arcadeDrive(forw/1.5, turn);
// Data printed to make sure joystick forward is positive and joystick turn is positive for right
work += " JF:" + forw + " JT:" + turn;
// Get sensor values:
double leftVelUnitsPer100ms = _lFront.getSelectedSensorVelocity(0);
double rghtVelUnitsPer100ms = _rFront.getSelectedSensorVelocity(0);
// double leftPos = _leftFront.GetSelectedSensorPosition(0);
// double rghtPos = _rghtFront.GetSelectedSensorPosition(0);
work += " L:" + leftVelUnitsPer100ms + " R:" + rghtVelUnitsPer100ms;
// Recognize any faults in the sensor:
_lFront.getFaults(_lFaults);
_rFront.getFaults(_rFaults);
if (_lFaults.SensorOutOfPhase) {
work += " L sensor is out of phase";
if (_rFaults.SensorOutOfPhase) {
work += " R sensor is out of phase";
// Print to drive station when button 1 is pressed:
if (btn1) {
System.out.println(work);
public void autonomous(){
_diffDrive.arcadeDrive(5, 0); //Drive forward at speed 5 and 0 rotation
Timer.delay(2.0); //Continue for 2 seconds
_diffDrive.arcadeDrive(0, 0); //Stop driving
if (Robot.limelight.getTV() != 1) { //Check to see if target is detected
autonomousSeeking();
public void autonomousSeeking() { //Attempts to find target
if (!leftJoystick.getRawButtonPressed(EMG_Stp)) { //Checks autonomous kill button
_diffDrive.arcadeDrive(0.1, 0.1);
public void ranging() {
if (Robot.limelight.calcXDist() > 125) {
_diffDrive.arcadeDrive(0, -0.1);
if (Robot.limelight.calcXDist() < 115) {
_diffDrive.arcadeDrive(0, 0.1);
public void goto180() {
if (gyro.isConnected()) {
while ((!(gyro.getAngle() > 179 && gyro.getAngle() < 181)) && !leftJoystick.getRawButtonPressed(2)) {
_diffDrive.arcadeDrive(0.1, -0.1);
} else {
System.out.println("Gyro not connected!");
// This initializes everything in the subsystem, sets everything to "default":
public void initDefaultCommand() {
// Set all the values to factory default
_rFront.configFactoryDefault();
_rBack.configFactoryDefault();
_lFront.configFactoryDefault();
_lBack.configFactoryDefault();
// Set up the followers
_rBack.follow(_rFront);
_lBack.follow(_lFront);
// Flip values so robot moves forward when LEDs are green
_rFront.setInverted(true); // !< Update this
_lFront.setInverted(false); // !< Update this
// Set values that are backward, or inverted to whatever is opposite
_rBack.setInverted(InvertType.FollowMaster);
_lBack.setInverted(InvertType.FollowMaster);
// Adjust sensor phase so sensor moves positive when Talon's LEDs are green
_rFront.setSensorPhase(true);
_lFront.setSensorPhase(true);
// Make sure left and right are opposite.
_diffDrive.setRightSideInverted(false);
// Help this subsystem recognize that DriveCommand.java is its main command file
setDefaultCommand(new DriveCommand());
