Hello all!
We’ve suffered through a myriad number of problems with our autonomous command-based programming, specifically with our pneumatics controls.
Our error messages and code files are posted below. Any help helps, thank y’all so much!!
Robot.java
package org.usfirst.frc.team5212.robot;
import edu.wpi.first.networktables.NetworkTable;
import edu.wpi.first.networktables.NetworkTableEntry;
import edu.wpi.first.networktables.NetworkTableInstance;
import edu.wpi.first.wpilibj.*;
import edu.wpi.first.wpilibj.command.*;
import org.usfirst.frc.team5212.autonomous.commands.*;
import org.usfirst.frc.team5212.autonomous.subsystems.DriveBase;
import org.usfirst.frc.team5212.autonomous.subsystems.Pneumatics;
import com.ctre.phoenix.motorcontrol.can.WPI_TalonSRX;
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.buttons.Button;
import edu.wpi.first.wpilibj.buttons.JoystickButton;
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
//states
boolean compress_state = false;
boolean shoot_state = true;
//subsystem creations
static DriveBase driveBase;
static Pneumatics pneum;
Timer timer;
/* talons for arcade drive */
WPI_TalonSRX frontLeftMotor = new WPI_TalonSRX(RobotMap.frontLeftPort); //0 1 5
WPI_TalonSRX frontRightMotor = new WPI_TalonSRX(RobotMap.frontRightPort); //2 3 4
/* extra talons and victors for six motor drives */
//WPI_TalonSRX leftSlave = new WPI_TalonSRX(3);
//WPI_TalonSRX rightSlave = new WPI_TalonSRX(1);
//WPI_TalonSRX leftSecondSlave = new WPI_TalonSRX();
//WPI_TalonSRX rightSecondSlave = new WPI_TalonSRX();
WPI_TalonSRX leftSlave1 = new WPI_TalonSRX(RobotMap.leftSlave1Port);
WPI_TalonSRX rightSlave1 = new WPI_TalonSRX(RobotMap.rightSlave1Port);
WPI_TalonSRX leftSlave2 = new WPI_TalonSRX(RobotMap.leftSlave2Port);
WPI_TalonSRX rightSlave2 = new WPI_TalonSRX(RobotMap.rightSlave2Port);
DifferentialDrive drive = new DifferentialDrive(frontLeftMotor, frontRightMotor);
public static Joystick joy = new Joystick(0);
public static Button AButton = new JoystickButton(joy, 2);
// Button BButton = new JoystickButton(joy, 2);
AutonomousCommand ac = new AutonomousCommand();
NetworkTable table;
NetworkTableInstance inst;
NetworkTableEntry leftRawData;
NetworkTableEntry rightRawData;
final int DEFAULT_DRIVE = 0;
// speed of robot [0-1]
double speedR = .84;
double speedL = 0.71;
// double speedR = 1;
// double speedL = 1;
// UsbCamera camera0;
// UsbCamera camera1;
* This function is run when the robot is first started up and should be
* used for any initialization code.
public void robotInit() {
* take our extra talons and just have them follow the Talons updated in
* arcadeDrive
// leftSlave.follow(frontLeftMotor);
// rightSlave.follow(frontRightMotor);
timer = new Timer();
driveBase = new DriveBase();
pneum = new Pneumatics();
leftSlave1.follow(frontLeftMotor);
rightSlave1.follow(frontRightMotor);
leftSlave2.follow(frontLeftMotor);
rightSlave2.follow(frontRightMotor);
/* drive robot forward and make sure all
* motors spin the correct way.
* Toggle booleans accordingly.... */
frontLeftMotor.setInverted(false);
// leftSlave.setInverted(false);
frontRightMotor.setInverted(false);
// rightSlave.setInverted(false);
// Pneumatics Setup
//mainCompressor.setClosedLoopControl(true);
//mainCompressor.stop();
// solenoidOne.set(DoubleSolenoid.Value.kOff);
// ac.start();
CameraServer.getInstance().startAutomaticCapture();
// mainCompressor.setClosedLoopControl(false);
* This function is called periodically during operator control
AButton.whenPressed(new PrepareShoot());
System.out.println("Joy0Y:" + joy.getRawAxis(1) + "Joy1Y:" + joy.getRawAxis(3));
drive.tankDrive(-(1) * (speedL)*joy.getRawAxis(1), -(1) * (speedR)*joy.getRawAxis(3));
Pneumatics.java
package org.usfirst.frc.team5212.autonomous.subsystems;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.command.Subsystem;
import org.usfirst.frc.team5212.autonomous.commands.PrepareShoot;
import org.usfirst.frc.team5212.robot.*;
public class Pneumatics extends Subsystem {
Compressor mainCompressor = new Compressor(0);
// DoubleSolenoid solenoidOne = new DoubleSolenoid(0, 1);
boolean isEnabled = mainCompressor.enabled();
boolean pressureSwitch = mainCompressor.getPressureSwitchValue();
double current = mainCompressor.getCompressorCurrent();
// or we could do something related to Robot.somethingdu?
PrepareShoot ps = new PrepareShoot();
@Override
protected void initDefaultCommand() {
setDefaultCommand(ps);
System.out.println("Compressor init");
public void compressAir()
System.out.println("Compressor compressing");
mainCompressor.start();
public void stopCompress()
/* public void shootMyKintama () throws InterruptedException
solenoidOne.set(DoubleSolenoid.Value.kForward);
solenoidOne.wait(5000);
public void stopShooting ()
PrepareShoot.java
package org.usfirst.frc.team5212.autonomous.commands;
import edu.wpi.first.wpilibj.command.Command;
public class PrepareShoot extends Command {
Pneumatics pneum = new Pneumatics();
public PrepareShoot() {
super("PrepareShoot");
requires(pneum);
protected void initialize() {
System.out.println("command init");
// TODO Auto-generated method stub
protected void execute() {
System.out.println("Trying to compress");
pneum.compressAir();
protected boolean isFinished() {
return false;
protected void end() {
if (isFinished()) {
pneum.stopCompress();
else {
protected void interrupted() {
end();
Error Log
The error log simply keeps repeating the error
<packagename>.<Pneumatics.java:21>
<packagename>.<PrepareShoot.java:11>
in an infinite loop while the driver station is running,
there is no other error message that appears
We’d highly appreciate any help/advice you all could give us.
Thank you again,
team5212
