Would you support a five to ten second longer autonomous period if FIRST decided to implement it. I feel that many programmers do not feel it is worth it to spend their time for fifteen seconds and that if there was a little more time than more people would find it more important and thus making more people work on autonomous.
Please give your input on whether you think it should be made longer or not.
You can always have more time, but the point of a challenge is not having everything you need and still trying to finish it.
I don’t support making auton longer and I think it’s fine enough time, and those that won’t score a keeper now won’t score a keeper if there was an additional 5 or 10 seconds.
I think a longer autonomous mode would be great. Autonomous this year could be anywhere from 5 to 15 seconds longer and still be good. As long as the autonomous mode is not like FVC last year (45 seconds was a bit excessive) autonomous mode would be great.
Just from trying to explain the autonomous period to folks in the stands that come for a day or two (spectators) - it is difficult to explain. And it can be pretty boring. 5 to 10 more seconds would not help make it any more exciting at this point.
No, I like it how it is. Many teams have large difficulties simply doing autonomous, but that isn’t because of the length of time given, it’s because they find it simply impossible to do whatever action it is in any amount of time.
I think the best way to improve autonomous participation rates would be less fragile or easier to use autonomous-focused equipment. On both teams I’ve been on in 2006 and 2007, the camera broke or would inexplicably stop working pretty frequently. It takes a long time to set up, a long time to test, and requires a large area to practice in properly. Laptops with serial ports are growing fewer and fewer, and the ones that my teams have been able to afford typically have nonfunctional batteries, so on-field debugging is impossible.
I would LOVE an end-of-game autonomous mode. You could have the end-of-game bonus be being some specific point on the field at the end of the teleoperated period, and at another point at the end of the ending autonomous period.
Problem with an end of game one would be that you’d have issues with game damage possibly getting exacerbated by the robot doing things autonomously. For example: in 2004, our robot had two high-torque motors driving seperate worm gears that moved the arm. Once, one of the wires came undone but the team didn’t notice, and the unsynchronized worm gear action actually torqued the entire arm. With start-of-game autonomous, you can disable the autonomous mode to not damage things you’ve found are damaged. But if match damage breaks a chain or loosens a wire, trouble could ensue.
I agree. I am a programmer myself and I find it hard to do something in a time as short as 15 seconds. Our programming mentor, when he first found out how much time we had, told us that it probably was not worth the time. we attempted anyway.
Honestly, to combat that there are products out like the one Eldarion made available at http://falconir.com/ and there is a CODE database provided by a team (can’t remember the name or site) which is accepting past year code donations and I think that if people donated previous years’ autonomous codes, new teams could “reverse engineer” them and learn by subdividing (wrong word?) what is already there.
From our perspect this year… Auto mode was not worth 6 weeks of work for 2 points and a keeper…and we gave up the arm idea anyway early in the season.
Auto mode last year was worth 30 points plus a 10 point bonus. SWEET.
The amount of time for auto mode to us doesn’t really matter, but what it means to the match play does. It’s gotta be worth it or gain an advantage.
Both last year and this year seem good for timing. Last year we had an auto mode with camera, and it worked pretty good. This year, we don’t have one. So now we just sit still. We might come up with something later, but for now we sit for the whole time frame. If we had 15 seconds last year, I think we could have done more auto correcting to get the aim better, but we did it in the time required. I like it the way it is.
Last year was good. At the beginning of auto, robots moved - did something. Our team even scored 4 to 6 balls in the center goal with only timers. This year is bad. Robots don’t do anything until human control. This year the incentive to put resources into auto is all most nil. Does it really matter to the game if you score a keeper? The length of auto time is not the key it’s the value of possible points and game wining advantage that push teams to focus on auto. As far as auto value, the game designers blew it this year.
I find the concept of an end of match auto ---- interesting.
With Easy-C even teams like ours can do something useful in auto but it has to have a high value to the game. This year we will sit and wait for human play.
Isn’t robotics about taking human interaction out of the loop?
I agree this year’s Autonomous was of dubious value - although in high-scoring matches like the Waterloo Regional just concluded, the ‘keeper’ did have some importance.
Making Autonomous work though, requires a good machine, and excellent/innovative programming - it stretches the minds and creativity of the entire team. It engages the minds, not just the arm controlling the joystick!
While Easy/C makes it possible to have a one-liner Operator Control program - TankDrive(…,…,…,…) - Autonomous demands the programmers and the team add hardware (encoders and do a lot more work).
I hope, next year, the “rewards” for doing Autonomous well are once again “worth it” - as they were in the 2006 competition. Even this year, had the keeper ring been worth extra (20 points? 10 points?) it would have been more worthwhile.
I can say that in this year’s game especially the 15seconds is a really short time to do anything seriously cool…
for instance, I’m doing an ultrasonic radar system only autonomous (for style points :rolleyes: ) and it takes 14.78 seconds with NO SLIP UPS. Granted, the world doesn’t work this way, so usually it runs overtime even in simulation and can’t complete in the time allotted… even 5 extra seconds would be great!
I would love to have a longer autonomous time period. Mainly so our robot can get to the other side of the rack and score but our robot just isn’t fast enough. But we’re going to try and just score on the rack and if we can’t get it dialed in, our robot is just going to hurry to the other side so we can start grabbing the tubes off the wall. But the 15 sec does test the strengths of the programmer. When the robot scores within the 15 seconds perfectly, feels pretty good. Plus with the 15 sec., at least try, or be very creative.
i wouldn’t b in support of it. i say that because from what i have seen, only a small percentage of people take advantage of the autonomous mode. adding a couple of seconds would only add time to the “staring competition” that takes place at the begining of most of the matches.
I guess I don’t understand why more teams don’t do… SOMETHING in auto mode.
No one said you had to try and score.
If you have a arm all folded up, why don’t more people just unfold the arm and get ready for human play. Or move forward onto the field. Maybe you don’t have the time to perfect a camera based auto mode - but it’s not as hard to “get ready” for game play.
Maybe alot of teams never really thought about it…
I would support Autonomous being longer if there was actually something more to do.
As it is, 15 seconds is more than long enough to score on the front light or either side light. Since picking up another ringer is all but impossible in auton, we’ve got all the time to do what they expected us to do.
We even wrote in a part of the routine that backs the robot up so that a tube can get thrown in front of it - but that got too dangerous because if one lands on your flag you’re stuck.
In the end, auton this year stinks. It isn’t valuable enough to be worth it (even though we did it). I wish it was worth more, because it sure seems that in the world of robotics, auton is the part you should be focused on.
Perhaps this year they should hold an “auton olympics” where the robots that can do auton do it and are scored. Perhaps a seperate award for it as well. I’m a little stunned that “best auton mode operation” isn’t an award already.
